Van Der Graaff generator question.
  • Thread starter Thread starter templedog
    Generator
The discussion focuses on the charging mechanisms of Van Der Graaff generators, specifically regarding the charging of different materials. A standard Van Der Graaff generator typically charges aluminum spheres positively, but it can also be configured to charge negatively. While plastic objects are poor conductors and cannot easily be charged, they can be made conductive with materials like copper spray. The size of the aluminum sphere affects the amount of positive charge it can store, influencing the negative charge on grounded objects nearby. Techniques for charging a ping pong ball include grounding it or rubbing it with fur, with the effectiveness of each method being a topic of inquiry.
templedog
The aluminum sphere on it is generating a positive charge and the wand a negative. If I put a ball on the wand, will it charge the same way the big one does? Just opposite charge?
anyone know about this thing?
I guess what I'm talking about. Can you make a Van Der Graaff that works in the opposite? One that charges a plastic ball instead of aluminum or steel? but does it already do that? The wand? I'm pretty much incompetent when it comes to this.
Most Van de Graaff generators charge positive but they can also be build so that they will charge negative. When a grounded metal object is close to a positively charged VDG it will become negatively charged. Plastic objects don't conduct electricity and so they can't be charged up that easily. But you can charge a plastic ball by rubbing it.
Can I take a rubber/plastic/teflon ball that is hollow, and charge it negative? If I touch it would it zap me?does the metal object have to be grounded? or just attatched to the opposite brush? the one at the bottom?
Attaching it to the opposite brush will work too.
A rubber ball can not zap you. To get a shock all the electric charge in the ball would have to flow into you within a tiny fraction of a second. That can only happen when the ball is a good conductor.
But you could spray the ball with copper or graphite spray to make it conductive.
If I spray paint a stainless steel gazing ball, will it still give a spark?
Does the negative charge get stronger if the aluminum sphere is larger? or does that matter?
Sure, you can paint it. It will still work.
When the aluminum sphere is bigger it will store more positive charge. Whether the negative charge on the grounded object changes depends on different factors.
As long as the grounded object is not too close to the aluminum sphere it's charge is approximately proportional to (radius of the aluminum sphere) / (distance from the aluminum sphere).
If it's very close to the sphere it gets more complicated and the amount of charge depends mostly on the distance since the distance determines how high the voltage can be before a spark jumps over.
Can i charge a ping pong ball with a negative charge by putting the ground wire in one through a small hole in it?or only by rubbing it with fur? or both? If both, I wonder which is best?
