Variation of the Einstein-Hilbert action in noncoordinate basis
  • Thread starter Thread starter center o bass
    Basis Variation
center o bass
The variation of the Einstein Hilbert action is usually done in coordinate basis where there is a crucial divergence term one can neglect which arise in the variation of the Ricci tensor, and is given by ##g^{ab}\delta R_{ab} = \nabla_c w^c## where
$$w^c = g^{ab}(g^{db} \delta \Gamma^{c}_{db} - g^{cb} \delta\Gamma^c_{db})$$.
However, when one varies in a noncoordinate basis, one supposedly (see link below) get's an extra term and arrive at
$$g^{ab}\delta R_{ab} = \nabla_c w^c - C^c_{cd} \delta \Gamma^d_{ab}g^{ab}.$$
How is this result derived?
My calculations so far is the following: From the Riemann tensor in a noncoordinate basis ##\{e_a \}## with structure constants ##[e_b, e_c] = C^a_{bc}e_a## given by
$$R^a_{bcd} = e_c \Gamma^a_{db} - e_d\Gamma^a_{cb} + \Gamma^f_{db} \Gamma^a_{cf} - \Gamma^f_{cb} \Gamma^a_{df} - C^f_{cd} \Gamma^a_{fb}$$
the variation yields
$$\delta R^a_{bcd} = e_c \delta \Gamma^a_{db} - e_d\delta \Gamma^a_{cb} + \delta\Gamma^f_{db} \Gamma^a_{cf} + \Gamma^f_{db} \delta\Gamma^a_{cf} - \delta\Gamma^f_{cb} \Gamma^a_{df} - \Gamma^f_{cb} \delta \Gamma^a_{df} - C^f_{cd} \delta \Gamma^a_{fb}- \delta C^f_{cd} \Gamma^a_{fb}$$
From here we can extract three terms of the respective covariant derivatives ##\nabla_d \delta \Gamma^a_{cb}## and ##\nabla_c \delta \Gamma^a_{db}##; however the terms ##\Gamma^f_{cd}\delta \Gamma^a_{fb}## and ##\Gamma^f_{dc} \delta \Gamma^a_{fb}## are not present. Taking these into account, I get
$$\delta R^a_{bcd} = \nabla_c \delta \Gamma^a_{db} - \nabla_d \delta \Gamma^a_{cb} + (\Gamma^f_{cd} - \Gamma^f_{dc}) \delta \Gamma^a_{fb} - C_{cd}^f\delta\Gamma^a_{fb} - \delta C_{cd}^f\Gamma^a_{fb}= \nabla_c \delta \Gamma^a_{db} - \nabla_d \delta \Gamma^a_{cb}- \delta C_{cd}^f\Gamma^a_{fb}.$$
If there are no error in my calculations, where do I go from here? Assuming I have done nothing wrong so far, it seems like one must achieve the equality ##\delta C_{cd}^f\Gamma^c_{fb} g^{db} = C^c_{cd} \delta \Gamma^d_{ab}g^{ab}##.. Any ideas on how this equality might be obtained?Equation (2.9) in: http://scitation.aip.org/content/aip/journal/jmp/15/6/10.1063/1.1666735
As the subject of the thread states, I wonder about noncoordinate bases. I.e. bases for which ##e_a \neq \partial_a##.
Tangent space basis vectors like ##e_a = f \partial_a## commute, so the problem goes away for them.
If ##{C^f}_{cd}## is constant, then is ##\delta {C^f}_{cd} = 0## ?
In which case you need ## {C^c}_{cd} = 0##, which could be the case.
[Edit]
I guess you saw my deleted post.
[Edit]
When one varies the components of the
metric (expressed in a basis), one also varies the associated basis, and since the structure constants are spacetime functions associated to a particular basis, these varies too. Thus, it seems like the variation of the structure constant does not disappear.
[Edit]
To correct my previous answer to you, I do agree that the structure constants are constant, since the variation is performed for a fixed basis.
Thus, the mystery where the additional term involving ##C_{cd}^{\ \ c}## comes from is even bigger.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
