Vector Algebra: Finding Resultant Forces at Optimal Angles | Expert Help
The discussion revolves around determining the angles at which two forces, represented as vectors ##\vec A+\vec B## and ##\vec A-\vec B##, must act so that their resultant has a specific magnitude of $$\sqrt{A^2+B^2}$$. Participants are exploring vector addition and the implications of the resultant's magnitude in the context of vector algebra.
  • Mixed
  • Participants are attempting to derive the resultant vector from the given forces and are questioning the implications of the resultant's magnitude. Some express confusion regarding the relationship between the vectors and the resultant, while others suggest simplifying the problem or reconsidering the assumptions made.
The discussion is ongoing, with various interpretations being explored. Some participants have provided insights into the relationships between the vectors, while others have pointed out potential misunderstandings in the original question. There is no explicit consensus, but several lines of reasoning are being examined.
Participants note that the question may have been misinterpreted, and there is a discussion about the dependency of the resultant on the vectors involved. The original poster's phrasing of the problem is also under scrutiny, with some suggesting that the question may not have been framed correctly.
IonizingJai
Question: At what angles must be the two forces ##\vec A+\vec B## and ##\vec A-\vec B## act so that the resultant may be :
$$\sqrt{ A^2+B^2}$$
Attempt at solution :
Let the given forces be ##\vec F_1=\vec A+\vec B## and ##\vec F_2=\vec A-\vec B## .
Now, Resultant vector : ##\vec F_1 + \vec F_2 = (\vec A+\vec B) + (\vec A-\vec B) ## .
Magnitude of Resultant: ##|\vec F_1 + \vec F_2| = \sqrt{(A+B)^2+(A-B)^2+2(A+B)(A-B)\cos(\theta)}##.
Here, ##\theta## being the angle between ##\vec F_1 and \vec F_2## .
Stuck here ##=\sqrt{2(A^2+B^2)+2(A^2-B^2)\cos(\theta)}## .
[ I'm noob with LaTeX too.].
$$\sqrt{ A^2+B^2}$$
You realize that ##(\vec{A}+ \vec{B})+ (\vec{A}- \vec{B})= 2\vec{A}## don't you? And, since the magnitude of ##2\vec{A}## does not depend on ##\vec{B}##, I have to ask "the resultant of what"?
You seem to have misunderstood the question.
$$\sqrt{ A^2+B^2}$$
Do not start a new thread for the same question already asked.
It's OK, Ray. I asked him to start a new thread, as I locked and will soon delete the old thread.
HallsofIvy said:
You realize that (A⃗ +B⃗ )+(A⃗ −B⃗ )=2A⃗ (\vec{A}+ \vec{B})+ (\vec{A}- \vec{B})= 2\vec{A} don't you? And, since the magnitude of 2A⃗ 2\vec{A} does not depend on B⃗ \vec{B}, I have to ask "the resultant of what"?
Yeah , i never approached the problem this way, sorry.
Also i found another way :
Now, Resultant vector ##\vec F_1 + \vec F_2 = (\vec A+\vec B) + (\vec A-\vec B)##
......1
But according to question the Resultant may be (but it should have been magnitude of the resultant, the question btw is correct as i read it.)
## = \sqrt{(A^2+B^2)}##
.....2
Equating 1 and 2 we get .
and ## 2(A^2+B^2)+2(A^2-B^2)\cos\theta = (A^2+B^2) ## .
and ##2(A^2-B^2)\cos\theta = - (A^2+B^2)## .
and ##\cos\theta= -1/2 ##.
That is ##\theta = cos^{-1}(-0.5)##
##\theta = - 120 degrees## between the two Forces ##\vec F_1 and \vec F_2## .
Simplify what's above!
You're making this much harder than it needs to be.
##|\vec F_1 + \vec F_2| = \sqrt{(A+B)^2+(A-B)^2+2(A+B)(A-B)\cos(\theta)}## ......1
## = \sqrt{(A^2+B^2)}## .....2
Alright , then that means i am wrong. So , if the question is correct , it ask for the value of the angle between the two forces so that the Resultant maybe
## \sqrt{(A^2+B^2)}##.
Mark44 : as you said i should simplify the but HallsofIvy already showed its not possible to arrive on the answer, since it will equal ##2\vec A## ?
Help ?
BTW , The question as asked in the First post is exactly as it is in language and i just copied it there.
So (A + B) + (A - B) = 2A, right?
What's the magnitude of the sum of the two vectors (which would be the magnitude of the resultant of A + B and A - B)?
##A\sqrt{2}##
Is this correct? $$ \frac{0}{3} = \frac{0}{5} \Rightarrow \,\text{beacuse}\, 0=0 \,\text{then}\, 3=5 $$
If you want:
$$ |\mathbf{F}_1+\mathbf{F}_2| = 2A = \sqrt{A^2+B^2} \Rightarrow 3A^2 = B^2 $$
that mean B2=3A2 and A is what you like or vs.
Will ( A vector) +(B vector) have a magnitude (|A|+|B|)2?
IonizingJai said:
##A\sqrt{2}##
No, that is still wrong! Assuming that you have stated the problem correctly, so that A+ B+ A- B= 2A, the length of 2A is NOT [itex]\sqrt{2}[/itex] times the length of A.
This is the initial problem: the "resultant" of two vectors A and B must be ##\sqrt{A^2+B^2}##.
The writer works on |resutlant|.
The other posibillity is that mean:
$$ \sqrt{A^2+B^2} = (\mathbf{A}+\mathbf{B})\cdot(\mathbf{A}-\mathbf{B}) = A^2 + B^2 +2AB\cos{\theta} \Rightarrow \cos{\theta} = \frac{\sqrt{A^2+B^2}-(A^2+B^2)}{2AB} $$
what I can say?
Sorry , but i don't get what are you guys implying ?
This isn't correct. For example, ##\lvert \vec F_1 \rvert^2## isn't equal to ##A^2 + B^2##, and ##\lvert \vec F_1 \rvert## isn't equal to ##A+B##. Rather, it should be
$$\lvert \vec F_1 \rvert^2 = \lvert \vec{A} + \vec{B} \rvert^2 = A^2 + B^2 + 2AB\cos\theta_\text{AB},$$ and ##\lvert \vec F_1 \rvert## is the square root of that. You might get the feeling this approach is going to be really messy, and you'd be right. Use Mark's suggestion to simplify first.
Thanks for replying vela,
but if you check my solution at post NO , #5 , i have done exactly what you said , i have only left the steps in which i had to cancel many things out and expand and stuff. if you check it you will find that i have done.
and i don't get what Mark44 is implying , the question gets stuck that way since, ##\vec A## will not depend on ##\vec B## and thus there will be no angle between them ?
Reread what I wrote a bit more carefully. You should see that your expression for the magnitude of the resultant is incorrect.
By the way, I suspect you used ##\sqrt{A^2+B^2} = A+B##. That's wrong too.
  • · Replies 18 ·
