Vector Analysis Problem Involving Divergence
The forum discussion centers on proving that the expression \nabla f \cdot \nabla(\nabla^2 g) - \nabla g \cdot \nabla(\nabla^2 f) can be represented as the divergence of a vector function involving scalar functions f and g. Participants utilized vector calculus identities, particularly the divergence and second derivative identities, to manipulate the expression into the form \nabla \cdot \vec{V}. Ultimately, one user successfully resolved the problem by constructing a vector field based on the suggestion to use a linear combination of \nabla f and \nabla g.
  • Understanding of vector calculus identities, particularly divergence and second derivatives.
  • Familiarity with the notation and operations involving gradients and divergences.
  • Knowledge of scalar functions and their properties in vector analysis.
  • Ability to manipulate vector expressions and perform component-wise comparisons.
  • Study the derivation and applications of vector calculus identities from Wikipedia.
  • Learn how to construct vector fields from scalar functions in vector analysis.
  • Explore advanced topics in divergence and curl in vector calculus.
  • Practice problems involving the manipulation of gradients and divergences in various contexts.
Students and professionals in mathematics, physics, and engineering who are working with vector calculus, particularly those tackling problems involving divergence and scalar functions.
MyName
[/B]
Let f and g be scalar functions of position. Show that:
\nabla f \cdot \nabla(\nabla ^2 g)-\nabla g \cdot \nabla(\nabla ^2f)
Can be written as the divergence of some vector function given in terms of f and g.
[/B]
All the identities given at https://en.wikipedia.org/wiki/Vector_calculus_identities, I suppose. Especially relevant would be the second derivative and divergence identites. Also, \nabla ^2 =\nabla \cdot \nabla
[/B]
After considerable time messing around with various vector identites, I've been able to show the above is equivalent to:
\nabla \cdot (f \nabla (\nabla ^2 g)-g\nabla (\nabla ^2 f))+g(\nabla \cdot \nabla(\nabla ^2 f))-f(\nabla \cdot \nabla(\nabla ^2 g))
This is painfully close to the result I want, but I can't seem to show that the second and third terms either cancel or are themselves a divergence. I'd really like any hints, and can provide more detail as to the specific identities and manipulations I've used thus far if needed, thanks.
Have you tried working it from the other end starting with the answer or is that an unknown?
MyName said:
[/B]
[/B]
[/B]
Those terms simplify to g \nabla^4 f - f \nabla^4g, which doesn't cancel.
Rather than building a vector field as a linear combination of \nabla(\nabla^2 f) and \nabla(\nabla^2 g), I would have started by building one as a linear combination of \nabla f and \nabla g.
Reference https://www.physicsforums.com/threads/vector-analysis-problem-involving-divergence.909435/
Unfortuntely the end result is unknown, otherwise that'd be a great suggestion, thanks!
Those terms simplify to g∇4f−f∇4g, which doesn't cancel. Rather than building a vector field as a linear combination of ∇(∇2f) and ∇(∇2g), I would have started by building one as a linear combination of ∇f and ∇g.
Yeah, I managed to get to that simplification, which like you said defnitely doesn't cancel, so I guess I must be able to somehow write the quantity as a divergence. I'm sorry, but I don't really understand what you mean by building a vector field?
Thanks for the help so far, I appreciate it.
I would write,$$\nabla f \cdot\nabla\left ( \nabla^2 g\right )-\nabla g\cdot \nabla \left ( \nabla^2 f \right ) =\nabla \cdot \vec V $$
Then do the work of expanding the l.h.s. in it's spatial components and compare with the r.h.s.
Consider the divergence of D(g, \nabla^2 g)\nabla f - D(f, \nabla^2 f) \nabla g for some function D.
I would write,∇f⋅∇(∇2g)−∇g⋅∇(∇2f)=∇⋅⃗V Then do the work of expanding the l.h.s. in it's spatial components and compare with the r.h.s.
That is a great idea, thanks! I managed to solve it using this idea.
