Vector & Gradient: Proving \phi=rk/r^{3}
  • Thread starter Thread starter gtfitzpatrick
    Gradient Vector
The discussion revolves around proving the gradient of the function \(\phi = \frac{rk}{r^3}\), where \(r = xi + yj + zk\). Participants share their differentiation attempts and express confusion over the correct application of differentiation rules, particularly the quotient rule. One user realizes they were only differentiating the \(1/r^5\) term and missing the gradient of \(z\) in their calculations. Clarifications are provided regarding the quotient rule and product rule, leading to a resolution where the user acknowledges their oversight. The conversation highlights the importance of correctly applying differentiation techniques in vector calculus.
gtfitzpatrick
if \phi = rk/r^{3} where r=xi + yJ + zk and r is the magnitude of r, prove that \nabla\phi = (1/r^{}5)(r^{}2k-3(r.k)r
so i differenciated wrt x then y then z and tried to tidy it all up but i got1/rClick to see the LaTeX code for this image(-3(r.k)r)
When i differenciated wrt x i got -3x/rClick to see the LaTeX code for this image and similar for y and z was this right?
then i just put these answers into Click to see the LaTeX code for this image = dx/dClick to see the LaTeX code for this image i + dy/dClick to see the LaTeX code for this image j + dz/dClick to see the LaTeX code for this image k
which gives
-3xz/rClick to see the LaTeX code for this image i - 3yz/rClick to see the LaTeX code for this image j - 3zz/rClick to see the LaTeX code for this image k
am i right so far? it just seemed to tidy up to 1/rClick to see the LaTeX code for this image(-3(r.k)r)
when it should be 1/rClick to see the LaTeX code for this image(rClick to see the LaTeX code for this imagek-3(r.k)r)
Hi gtfitzpatrick! :smile:
This is too difficult to read … everything has "Click to see the LaTeX code for this image" in the middle. :confused:
Can you type it out again, perhaps using ² and ³ and ^4 and ^5? :smile:
so i differenciated wrt x then y then z and tried to tidy it all up but i got 1/r^{5}(-3(r.k)r)
When i differenciated wrt x i got -3x/r^{5} and similar for y and z was this right?
then i just put these answers into = dx/d\phi i + dy/d\phi j + dz/d\phi k
which gives
-3xz/r^{5} i - 3yz/r^{5} j - 3zz/r^{5} k
am i right so far? it just seemed to tidy up to 1/r^{5}(-3(r.k)r)
when it should be 1/r^{5}(r^{2}k-3(r.k)r)
It's not terribly clear what you are doing, but some how you are winding up with only one part of a quotient rule answer. Your initial function is (r.k)/r^3. That's the same thing as z/r^3.
You know there is a 'quotient rule' for grad, yes? grad(f/g)=(g*grad(f)-f*grad(g))/g^2. Does that help?
which gives
You're only differentiating the 1/r^5.
You need to differentiate the r also. :smile:
i differenciated z(x^2+y^2+z^2)^{-3/2} wrt x then y then z, and then filled it into the fomula was this not right?
"you know there is a 'quotient rule' for grad, yes? grad(f/g)=(g*grad(f)-f*grad(g))/g^2"
I didn't know this, does this mean I'm wrong?i haven't seen this formula before what are the f and g's?
so i can't use the product rule?
It means you are missing a piece of the grad of z/r^3. In terms of the quotient rule, f is z and r^3 is g. You are missing the grad(f) part. Yes, you could also use the product rule, grad(z*r^(-3))=grad(z)*r^(-3)+z*grad(r^(-3)). You are missing the grad(z)*r^(-3) part.
thanks for getting back to me, i figured it out i was missing it,god it took me a age to get there Thanks again though
  • · Replies 20 ·
  • · Replies 0 ·
