Vector function for cone and plane intersection with different parameters
1 reply · 14K views
Litcyb
Find a vector function that represents the curve of intersection of the two surfaces:
The cone z = sqrt( x^2 + y^2) and the plane z = 1+y.
This problem can be solved as following using x as the parameter.
x^2+y^2 = z^2 = (1+y)^2 = 1+2y+y^2. => x^2 = 1 + 2y.
x=t; y = (t^2-1)/2; z = 1+(t^2-1)/2 = (t^2+1)/2
My question is, what if we use y as the parameter,
i get ,
y=t, x=(2t+1)^(1/2) z=t+1,
is this answer also correct?
i get ,
Sure, with the proviso that it only represents part of the curve. For example, points with negative values of x won't appear in the second parametrization (where you also should specify t>=(-1/2)). You'd need the x=(-(2t+1)^(1/2)) solution as well to get them all.
