Verifying Whether A Complex Function Is Differentiable
The discussion focuses on determining the differentiability of the function f(z) at z=0, defined piecewise with f(z) = \overline{z}^2/z for z ≠ 0 and f(0) = 0. The initial approach involves checking the continuity at z=0 and evaluating the limit of the derivative. The analysis reveals that as z approaches 0, the limit of the derivative depends on the angle θ, indicating that it does not exist. Consequently, it is concluded that f(z) is not differentiable at z=0. Additionally, a minor correction is noted regarding the use of mathematical symbols in expressions.
Bashyboy
The problem is to determine whether the function
##f(z) =
\left\{\begin{array}{l}
\frac{\overline{z}^2}{z}~~~if~~~z \ne 0 \\
0 ~~~if~~~z=0
\end{array}\right.##
is differentiable at the point ##z=0##. My two initial thoughts were to show that the function was not continuous at the point ##z=0##, which is may very well be (I don't know as of yet), or to show that the limit
##\frac{df}{dz} (z_0) = \lim\limits_{z \rightarrow z_0} \frac{f(z)-f(z_0)}{z-z_0}##
exists or does not. However, I am not sure of how to deal with the fact that ##f(z)## is a multi-part function.
Any suggestions?
Ah, I think I may have figured it out. Let me type up my solution, so that it might be verified...
Using the definition of the derivative given in the 1st post,
##\lim\limits_{z \rightarrow 0 } \frac{f(z) - f(z_0)}{z-z_0}##
Because ##z## only closely approaches 0, but is never actually zero, we know that ##f(z)## is evaluated by the first part of the definition:
##\lim\limits_{z \rightarrow 0 } \frac{\frac{\overline{z}^2}{z} - 0}{z-0} \iff##
##\lim\limits_{z \rightarrow 0 } \frac{\overline{z}^2}{z^2} \iff##
##\lim\limits_{z \rightarrow 0 } \left(\frac{\overline{z}}{z}\right)^2##
If we let ##z = r e^{i \theta}##, then
##\lim\limits_{z \rightarrow 0 } \left( \frac{re^{i \theta}}{r e^{- i \theta}} \right)^2 \iff##
##\lim\limits_{z \rightarrow 0 } e^{4 i \theta} \iff##
This limit does not exist, because the it has a different value depending upon which line of angle ##\theta## you travel towards ##0##. Therefore, the derivative does not exist at ##z=0##.
Minor point: Don't use ##\iff## to connect expressions that have the same value. Use = for these situations. ##\iff## is used between statements (usually equation or inequalities) that are equivalent; i.e., that have the same truth values.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
