Vessel of water under free fall
When a vessel of water is in free fall, water does not exit through a hole in the side due to the absence of pressure difference. Both the vessel and the water fall with the same acceleration, resulting in no net force acting on the water that would push it out. The pressure exerted by the weight of the water is neutralized as the vessel falls, leading to equal pressure at different levels of the liquid. This phenomenon is explained using Newton's laws, confirming that under free fall conditions, the forces acting on the water balance out.
  • Understanding of Newton's laws of motion
  • Basic knowledge of fluid dynamics
  • Familiarity with pressure concepts in fluids
  • Concept of potential energy in gravitational fields
  • Study fluid statics and dynamics to understand pressure variations in fluids
  • Explore the principles of free fall and gravitational acceleration
  • Learn about the applications of Newton's laws in fluid mechanics
  • Investigate the effects of pressure in different fluid scenarios, including pressurized vessels
Students of physics, engineers working with fluid systems, and anyone interested in the principles of motion and pressure in fluids will benefit from this discussion.
AdityaDev
When a Vessel of water is under free fall and there is a hole in the side of the vessel, why does no water come out of the vessel? (its given in my textbook that pressure exerted on sides of vessel is zero. But what does the horizontal force have to do with the vertically acting force due to gravity?)
Water has weight. It pushes down on the water below it, creating horizontal pressure. Under gravitational influence, the water seeks the lowest point of potential energy. It can do this by pouring out the hole.
The textbook says water does not flow out.
Why should it? The vessel falls with the same acceleration as the water, so it's not in its way.
(its in an Indian textbook, so there are grammatical errors)
I was addressing the default state: when the vessel is sitting on a surface.
You asked: "what does the horizontal force have to do with the vertically acting force due to gravity?"
I provided the answer. Under gravity, the water tries to squeeze horizontally.
So, with that part answered, does it now make more sense why the water would not flow out once gravity is neutralized?
Understood.
AdityaDev said:
There is no pressure due to the weight of the water, because the weight is not supported by the vessel (the vessel falls itself). There could still be pressure if the vessel is pressurized.
AdityaDev said:
This does not answer A.T.'s question.
Why should the water come out of the hole while the vessel AND water are freely falling?
It doesn't right?
AdityaDev said:
It doesn't right?
Well, you know that, having been told by the textbook. But do you now understand why?
Under free fall, if you consider an arbitrary cylinder of length y like this:
From Newtons laws, ##\Delta P.\Delta S+W=mg##
Then ##(P_1-P_2)\Delta S+y\Delta S\sigma g=y\Delta S\sigma g##, sigma is the density of liquid. The force acting are due to weight and due to pressure difference.
So, ##P_1-P_2=0##
hence, ##P_1=P_2##
So there is no pressure difference between 2 levels of the liquid.
I don't know if what i did is correct, but it does make sense and i have used nothing other than Newton's laws. Please verify this.
  • · Replies 31 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 25 ·
