How to Correct VHDL Code for Serial Input State Machine?
  • Thread starter Thread starter ellis91
    Machines State
The discussion focuses on creating a VHDL code for a state machine that processes serial input data in packets defined by a user-specified number of bytes. The code aims to identify a special byte marking the start of each frame, manage data reception, and handle errors when the special byte is not detected at expected intervals. The user seeks guidance on correcting their initial code attempt and understanding the overall structure and logic of the state machine. Suggestions include providing a state diagram to clarify the design approach and facilitate troubleshooting. The conversation emphasizes the importance of clear design documentation for effective code correction.
ellis91
VHDL help in state machines!
I have to write a vhdl code to accept inputs serially in the form of bytes(1 byte at a time). These bytes are in a particular order i.e they are received in packets where each packet is a frame with a specific number of bytes. This number of bytes in a frame can be defined by the user and is fixed. The main purpose of my code is to:
1. Assign one special byte to mark the beginning of each frame.
2. Search for the special byte in order to start receving data.
3. If the special byte is not found at regular intervals i.e after the number of bytes that the user defined, an error is indicated. Variables to keep count of the errors and the number of special bytes are assigned.
4. If the special byte is found before or after the specific number of bytes, then besides indicating an error, the code should resume receiving data from that special byte.
I know that i have to go about it using state machines, but i don't exactly understnd how the structure of the program and states should be
This was my attempt at the program and i know it is wrong. how can i correct it to do what i want it to do:
Code:
-- [B][B][B]entity packet_format_error_detection is
port (
      data_receive, special_byte : in STD_LOGIC_VECTOR(0 to 7);
        no_of_bytes : in STD_LOGIC_VECTOR(0 to 7);
        clock, subclock : in STD_LOGIC
end final_packet_format_error_detection;
architecture statemachine of packet_format_error_detection is
 type statetype is (IDLE, START_DETECTION, RECEIVE_DATA);
 signal state, next_state: statetype;
 signal no_error_bytes : integer range  0 to 1024;
 signal no_special_bytes : integer range 0 to 1024;
 signal byte_count : integer range 0 to 1024;
begin
operation: process(state, data_receive, special_byte, no_of_bytes, no_error_bytes, no_special_bytes )
begin
no_error_bytes <= 0;
no_special_bytes <= 0;
byte_count <= 0;
case state is
when IDLE => if(data_receive = special_byte) then
                 next_state <=    START_DETECTION;
                 else next_state <= IDLE;
                 end if;
when START_DETECTION => if( clock'event and clock = '1') then
                                    next_state <= RECEIVE_DATA;
                                else
                                end if;
when RECEIVE_DATA => if( subclock'event and subclock = '1') then
                                byte_count <= byte_count + 1;
                                    if(byte_count = no_of_bytes) then
                                        no_special_bytes <= no_special_bytes + 1;
                                        byte_count <= 0;
                                        next_state <= IDLE;
                                    else
                                        no_error_bytes <= no_error_bytes + 1;
                                        byte_count <= 0;
                                    end if;
                                 else
                                 end if;
                            else
                            end if;
end case;
                end process;
end statemachine;
[/B][/B][/B]
I can explain it in even better detail if necessary. Please help me at the earliest.
Can you provide some documentation on the design you are using? Graphs, flowcharts, processes, etc.
It is very difficult to "correct" code when you don't know the design information.
the main reason i put up the code was to give you an idea as to how i was approachin it.. i want help in finding out if this approach is good or there are other better ways of achieving the result.. i would like to know how to frame the logic of this program.. thanks in advance..
Code:
port (
begin
begin
byte_count <= 0;
case state is
                 end if;
                                else
                                end if;
                                        byte_count <= 0;
                                        next_state <= IDLE;
                                    else
                                        byte_count <= 0;
                                    end if;
                                 else
                                 end if;
                            else
                            end if;
end case;
                end process;
end statemachine;
[/B][/B][/B]
Welcome to the PF.
I agree with KingNothing -- please at least post your State Diagram to help make it easier to go through your code. Thanks.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
