Views On Complex Numbers
  • Topic: Insights
  • Thread starter Thread starter fresh_42
    Complex Numbers
108 replies · 18K views
Agent Smith said:
@fresh_42 I see. I'm amazed that a "simple" expression like ##e^{i \theta}## equals ##a + bi##. How?? 🤔
By Euler's formula, or if you prefer that, by expressing the same (complex) number ##z## once is Cartesian coordinates ##z=(x,y)=x+iy## and then by polar coordinates ##z=r\cdot e^{i \varphi }## where ##r=|z|=\sqrt{x^2+y^2}## and ##\varphi ## determined by ##\dfrac{x}{r}=\cos \varphi ## and ##\dfrac{y}{r}=\sin \varphi .## It uses the fact that we can represent complex numbers in a planar coordinate system with a real axis (##x##) and a purely imaginary axis (##i y ##).
Agent Smith said:
So if ##z = 1## then ##1 = |1| \times e^{i \times 0} = e^0 = 1##?
Yes.
@fresh_42
I'm a bit unsure about how ##r \cdot e^{i \phi} = z = a + ib, r = \sqrt {a^2 + b^2}##
The "=" sign doesn't seem to have the same meaning as in ##2 + 3 = 5## or ##7.5 = 7.5##
It’s polar coordinates generalized to the complex plane.
Sorry, couldn't parse that. I know that graphically, ##r \cdot e^{i \phi} \overset{?} = z = a + ib##. I've seen the vector/complex number plot in the complex plane, they're identical. So am I supposed to interpret the equality graphically, as representing the same vector (the same complex number)?
##e^{i \varphi}## is the line segment ##(0, 0) \text{ to } (1, 0)## rotated counterclockwise by an angle ##\varphi##?
reiφ is a complex number.
We know that any complex number can be written as a+ib.
So “normal” equality holds.
While one can apply “vector like operations” to complex numbers, they are more than that. That is the major point of the Insight.
Gracias, but do I have a case if I say that the equality ##re^{i\varphi} = a + ib## is not as evident/obvious as the one you see in ##5 = 5##? These are representations of the same mathematical object (complex numbers) in 2 different systems (polar coordinate system and the usual Cartesian coordinate system). It's more like saying that love (English) = Ishq (Urdu) than saying love = love, right? 🤔
No. You want to view a+ib as a vector and reiφ as a scalar which makes “=“ ambiguous. They are both complex numbers with a clean definition of “=“.
I still don't get it. When I say ##y = 2 + 3## I know that ##y = 5## and that ##5 = 2 + 3##. I can, looks like, unpack the ##5## into ##3 + 2##. Can I do something to ##e^{i \varphi}## (is there an algebraic algorithm?) to get to ##a + ib##?
I do know that ##e^{i \varphi} = \cos \varphi + i \sin \varphi##, but it's the same issue here too. Is there summation of a series or a limit of a function or something else involved in proving this equality? 🤔
Agent Smith said:
Gracias, but do I have a case if I say that the equality ##re^{i\varphi} = a + ib## is not as evident/obvious as the one you see in ##5 = 5##? 🤔
Good point. In fact, the definition of what a complex exponent means is not so simple. The correct meaning of ##e^{i\theta}## can only be accepted after some work. The work is not elementary. I think that the definition that stays within the more basic facts is the limit definition. The associated proofs are still not elementary. That is why it took a genius like Euler to discover Euler's formula.
PS. You should get comfortable in knowing that there are solid proofs that Euler's formula, ##e^{i\theta}=\cos(\theta)+i \sin(\theta)##. Then you are free to use it and forget the details of the proof. It is very useful.
Imagine any point in a planar, two-dimensional coordinate system, except the origin that requires particular handling since the distance between the origin and the origin is zero and we cannot measure an angle between two lines of length zero.
So given any point ##z## in that grid, the coordinate system of the plane. How would you describe it to me if I asked you to show me a way from the origin to the point ##z##?
As I see it, you could either tell me to go ##a## units to the right and ##b## units to the top, which means in equations that ##z=(a,b)=a+ib## if we identify the plane with complex numbers, or you could tell me turn myself and look horizontally to the right, then turn myself by an angle of ##\varphi ## counterclockwise and walk ##r## units into the new direction, which means ##z=(a,b)= r\cdot e^{i \varphi }.##
##r=|z|=\sqrt{a^2+b^2}## (Pythagoras) and times ##e^{i \varphi }## is the turning from looking horizontally to looking towards ##z.##
There are several ways to see why times ##e^{i \varphi }## is a counterclockwise rotation of the point ##(r,0)## to the point ##(a,b).## One is to look at Euler's formula (as linked to twice in previous posts) or by the study of complex multiplication (see picture in post #59). The only ambiguity here is, that the vertical coordinate is once the second in ##(a,b),## the ##b## and at the same time identified with the complex number ##i b##. You can imagine this as units. We have the unit ##[1]## horizontally and the unit ## [\mathrm{i}]## vertically. We do not write the units in ##(a,b)## if we refer to a point on the grid, and do write the units if we identify such a point with a complex number: ##(a,b)=a+ i b.##
martinbn said:
Some people call certain objects "comex curves", other people call them "Riemann surfaces".
Ah, the commercial exchange. They got great curves ;).
fresh_42 said:
Separating complex numbers into real and imaginary parts is exactly what this article wants to put into the second row of consideration, and viewing complex numbers as elements of one field in the first place rather than reducing them to a simple, real vector space.
This narrowed view as ##a+ib## is in my opinion what hides the beauty of complex analysis, or the algebraic background of complex numbers. It is a widespread disease and not really helpful. This article was all about
\mathbb{C} \neq \mathbb{R}^2.
At what level of structure? Clearly one is an Algebra, while Euclidean space isn't. Though they are Topologically but not Geometrically identical.
Before getting into more advanced subjects like Riemann surfaces, there are conformal mappings between simply connected open sets in the complex plane.
The complex numbers and the real numbers carry many structures. I wanted to point out the field structure because that is what is necessary for doing complex calculus. The vector space structure is insufficient. Two-dimensional real analysis and complex analysis are very different. Yet, students are introduced to complex numbers via the Gaußian plane. They start with a handicap for no reason and everything appears to be miraculous when complex analysis starts - only because some teachers prefer to draw little arrows instead of teaching the algebra as a field behind it. And the algebraic part of an algebraic closure and the field axioms aren't even difficult. But no, little arrows rule. This is in my opinion a bad approach. The little arrows are necessary, but after the algebraic subject is settled, not before. There is a reason people come up with equations like
-1=\sqrt{-1}\cdot \sqrt{-1} =\sqrt{(-1)\cdot(-1)}= \sqrt{1}=1 \quad (*)
The reason is, that in the world of little arrows, everything looks real, just two-dimensional. I know, that my opinion is inconvenient since it is against the inertia of the old argument: We always did it this way.
I need the two-dimensional view, too, by writing ##\mathbb{C}\cong \mathbb{R}[T]/ \bigl\langle T^2+1 \bigr\rangle ,## of course not without mentioning that ## \bigl\langle T^2+1 \bigr\rangle## is a maximal ideal. My imaginary unit would be the holomorphic image ##t## of the variable ##T## and ##(*)## would be impossible to set equal:
-1 \equiv t^2 \equiv t\cdot t \not\equiv 1\cdot 1 =1.
The algebraic view is also the key to understanding that complex numbers don't have an Archimedean order and that squares are not automatically positive anymore. If these concepts are settled, let's speak about our handicapped possibilities to visualize complex numbers despite the fact that
\mathbb{R}[T]/ \bigl\langle T^2+1 \bigr\rangle \neq \mathbb{R}[T]/ \bigl\langle T^2 \bigr\rangle
fresh_42 said:
The complex numbers and the real numbers carry many structures. I wanted to point out the field structure because that is what is necessary for doing complex calculus. The vector space structure is insufficient. Two-dimensional real analysis and complex analysis are very different. Yet, students are introduced to complex numbers via the Gaußian plane. They start with a handicap for no we everything appears to be miraculous when complex analysis starts - only because some teachers prefer to draw little arrows instead of teaching the algebra as a field behind it. And the algebraic part of an algebraic closure and the field axioms aren't even difficult. But no, little arrows rule. This is in my opinion a bad approach. The little arrows are necessary, but after the algebraic subject is settled, not before. There is a reason people come up with equations like
An interesting question is whether we can define s multiplication in ## \mathbb R^2## to turn it into an Algebra. The standard inner product won't work, but why not other operation? Edit:nd ##<T^2>## is not maximal, so quotient wont be a field. But, good point, the two aren't order-isomorphic. Similar for ##\mathbb C^{n}## and ##\mathbb R^{2n}##.
WWGD said:
An interesting question is whether we can define s multiplication in ## \mathbb R^2## to turn it into an Algebra. The standard inner product won't work, but why not other operation? And ##<T^2>## is not maximal, so quotient wont be a field.
You could multiply it componentwise, or use a Lie multiplication of a two-dimensional real Lie algebra. However, you won't get a field, except if you use the graduation ##\mathbb{R}\oplus i \mathbb{R}## with ##(i\mathbb{R})\cdot (i\mathbb{R}) \subseteq \mathbb{R}.##
It requires taylor series.
That is one good way. There are a couple of ways to define the complex exponent and each definition of ##e^{i\theta}## has its own proof of Euler's formula. Wikipedia has a few options here.
Asante sana. That's quality advice. So there are intriguing bridges (@MidgetDwarf ), like The Taylor Series.
It was like A = B and B = C, hence A = C than a more direct A = C (here B is the "intriguing bridge")
Arigato gozaimus for the explanation. It's clearer now. We have 2 ways of representing the same object, one with polar coordinates (length, angle) and the other with normal Cartesian coordinates (with an x and a y). I did a bit of informal history of mathematics years ago, but seem to have forgotten which of the two ideas, vectors/complex numbers, came first. Either way, it's nice to see them complement each other like this.
The field structure is not enough, you need the absolute value. Otherwise you could do calculus in any field, which is not the case.
Yes, but the two dimensional real space has additional structure, the complex structure. It is possible, and often done, to view any complex manifold as a real manifold with a complex structure.
I don't think the first introduction of complex numbers is always done with the idea that they are needed for complex analysis. Some think of them from a more algebraic point of view. I think the choice to emphasize the complex plane is purely pedagogical. Also, I think that if you stress that the complex numbers are a field, complex analysis will still look like a miracle.
No, I don't think your opinion is inconvenient, but I also don't see the problem with the standard aproach to complex numbers. The more ways to see something the better the understanding.
It is funny you should say that, because the dual numbers ##\mathbb{F}[T]/ \bigl\langle T^2 \bigr\rangle## can be used to define the arrows that you objected to.
Very well said. I can't think of a good way to go from field properties to geometric properties like conformal mappings, although it does set the stage for inner product spaces.
I believe ##e^z## is the only Analytic extension to the Complex Plane satisfying ##\frac {de^z}{dz}=e^z##.
But you have a valid point, imo. If ##z## is a Complex variable, why is it broken into Real and Complex parts in so many settings?
Are there intermediate extensions between ## \mathbb Q \subset \mathbb R \subset \mathbb C ##
Never mind. Tower theorem makes the intermediate extensions impossible.
Exactly, that's my point. This is the arrow world and ##\mathbb{F}[T]/ \bigl\langle T^2+1 \bigr\rangle## something completely different.
I conclude that you are so hardened in your personal opinions that you aren't willing to even consider my point of view. There is no way to reason against "We always did it this way!".
What's next? "If everybody would do this?" or "I have my rules."?
You could at least accept that not everybody thinks that "We always did it this way!" is a satisfactory argument.
What exactly do you mean by an arrow?
How? How do you know my opinion? I haven't expressed it!
