Is Visible Light Bremsstrahlung Observable in Transparent Mediums?
Visible light bremsstrahlung can be observed when an electron beam, even at low energies (around 3 eV), interacts with a transparent medium. The theoretical bremsstrahlung spectrum is flat at low photon energies, indicating that high-energy electron beams can emit visible photons, albeit with low efficiency. Observations of continuous spectra in the visible region are challenging, particularly in low-pressure gases or vacuum tubes. Cerenkov radiation, which can also occur in transparent mediums, demonstrates that visible emissions are possible under specific conditions.
  • Understanding of bremsstrahlung and its spectral characteristics
  • Knowledge of electron beam interactions with matter
  • Familiarity with Cerenkov radiation and its properties
  • Basic principles of photon energy and emission mechanisms
  • Research the mechanisms of bremsstrahlung in various materials
  • Explore the properties and applications of Cerenkov radiation
  • Investigate the effects of electron beam energy on photon emission
  • Learn about experimental setups for observing visible light emissions from electron beams
Physicists, researchers in particle physics, and anyone interested in the interactions of electron beams with transparent mediums and the resulting photon emissions.
nightvidcole
Summary: Can one observe visible light bremsstrahlung when an electron beam stops in a transparent medium?
The theoretical form of a bremsstrahlung spectrum is flat at low photon energies. This means that even a high energy electron beam incident on matter should cause the emission of visible photons, albeit with extremely low efficiency. So why is it so hard to observe a continuous spectrum ( and not just line emission) in the visible region from cathode rays in a low pressure gas or a vacuum tube with residual gas?
Science news on Phys.org
I think that 'low photon energies' means low for X Rays. I was trying to think of how electrons of, say 3eV energy, could be passed through a dense transparent medium and produce visible photons (of that sort of energy). I thought that, to produce bremsstrahlung, you needed an electron beam to penetrate the substance.
Yes, you can see it, but I won't recommend looking at it
That would all depend on the energy of the beam. A few eV is enough KE if you can actually get it to penetrate a suitable substance to produce optical frequencies.
The blue'ish glow that one sees in a water pool of a nuclear reactor is such Cerenkov radiation.
I've also done measurement on the Cerenkov radiation given off when 40 MeV electron bunches slam into a piece of Aerogel to measure the longitudinal bunch length of those electron bunches. Again, that's in the visible range.
There's nothing in the physics that indicates that a Cerenkov radiation can't be in the visible spectrum.
Zz,
No, I've seen it, I accidently looked into the x-ray source when it wasn't blocked. It does glow.
I was questioning the idea that it would have to be risky (as in your case). I was suggesting that bremsstrahlung could be generated (safely) with a low energy beam in the 'appropriate' transparent medium.
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 21 ·
35K
