Voltage and current calculation on a mixed circuit
2 replies · 9K views · last reply
sylvarant
I have the following circuit
http://informatici.vankeer.eu/files/2/Untitled.png
R1 = 22 ohm, R2 = 39, R3 = 82, R4 = 100,R5 = 10
and V = 2volt
I'm asked to calculate the voltage and current over de resistors
when the switch is open and when the switch is closed
when 2 resistors form a combination the current is the same and V = IR
when 2 resistors are in parallell there voltages are the same and Ii = V/Ri
well when the switch is open I obtain the following
the resistors R1 and R4 form a combination and so do R2 and R3 the voltage remains equal for both combinations so we can easily calculate the current
I1=I4 = 2v/(22+100)ohm = 0.016 A
now we find the voltage over both resistors
V1= 0.016 * 22 = 0.361 Volt
v4 = 0.016 * 100
Same way for I2 and I3
But I'm stuck when the switch is closed how do I calculate the current and voltage then ?
It might be well to read up on "Delta-Wye" transformations.
Have you learned how to write KCL equations yet? Write the two KCL equations for the left and right nodes, and solve for the two unknowns V(left node) and V(right node).
