Volume of cross sections using isosceles right triangle
2 replies · 13K views
mikaloveskero
The area is bounded by the equation y=x^2, x-axis and the line x=3 and is perpendicular to the x axis
A=1/2bh
Height=Base
A=1/2B^2
V=1/2B^2 from 0 to 3
V=1/2 B^3/3 from 0 to 3
V=B^3/6 from 0 to 3
V=27/6
please tell me if I am doing something wrong, on the right track or I'm correct
Are we to assume that the cross sections perpendicular to the x-axis are "isosceles right triangles"- with one leg perpendicular to the x-axis or the hypotenuse?
I think what you are trying to do is correct but your notation is very strange. You are given information about x and y- use them, not new variables! Assuming it is the leg that lies perpendicular to the x-axis then the other leg is just y= [itex]x^2[/itex]. The area of such a triangle is [itex](1/2)(x^2)(x^2)= x^4/2[/itex]. The "thickness" of each such cross-section is [itex]\Delta x[/itex] so the volume is [itex](1/2)x^4\Delta x[/itex]. In the limit that becomes an integral.
Its perpendicular to the x-axis not the hypotenuse. Also I combined the variables as one because the height is equal to the base. Also, we weren't taught thickness so that information is not needed. However , in my problem i realize i forgot to plug in X^2
So redoing my work it would be :
V=x^5/10 from 0 to 3 which is equal to 243/10 , therefore your answer should agree with mine after you integrate your work. I'm just not sure where the thickness part come in since i have not learned that yet
