Volume of cylinder with differentials
The discussion focuses on estimating the volume of tin in a closed tin can using differentials. The can has a diameter of 8 cm and a height of 12 cm, with a tin thickness of 0.04 cm. The volume of the cylinder is calculated using the formula V = πr²h, leading to a differential volume dV = 2π(8)(12)(0.04), which approximates to 24 cm³. However, considering the top and bottom of the can, the correct volume of tin is confirmed to be 16 cm³.
  • Understanding of differential calculus, specifically the application of differentials in volume calculations.
  • Familiarity with the formula for the volume of a cylinder: V = πr²h.
  • Knowledge of geometric concepts, particularly the distinction between diameter and radius.
  • Basic skills in algebra for manipulating equations and performing calculations.
  • Study the application of differentials in real-world volume estimations.
  • Learn more about the geometric properties of cylinders and their implications in volume calculations.
  • Explore advanced differential calculus techniques for multi-variable functions.
  • Review problems involving the integration of volume calculations with varying dimensions.
Students studying calculus, particularly those focusing on applications of differentials in geometry, as well as educators looking for examples of volume estimation techniques in practical scenarios.
Asphyxiated
Use differentials to estimate the amount of tin in a closed tin can with diameter 8cm and height 12cm if the tin is 0.04cm thick.
If:
z=f(x,y)
then
dz = f_{x}(x,y)dx+f_{y}(x,y)dy
Perhaps my problem here has to do with the top and bottom of the canister not being taken into account explicitly. If this is the case I can not see it on my own however.
First the volume of a cylinder is:
V=\pi r^{2}h
where here:
r=8cm \;\; h=12cm
the differential of the volume should then be:
dV=(2 \pi r h) dr + (\pi r^{2}h) dh
where in this problem:
dr=0.04cm \;\; dh=0cm
so the second term vanishes and in the calculation we get:
dV= 2 \pi (8)(12)(0.04) \approx 24 cm^{3}
however the answer section tells me that it should be 16cm^3 but if i do the calculation with just geometry I get the same thing, i.e.:
V_{tin}=12 \pi (8^{2}-(8-0.04)^{2}) \approx 24 cm^{3}
If the top/bottom of the container were to be taken into account it would only add to this number from my view.
Am I doing something wrong or is the book just wrong here?
The diameter of the can is 8 cm; the radius is 4 cm.
ha, ok... for some reason I always do that when I haven't dealt with radius vs diameter in awhile, sometimes I need the obvious pointed out :)
thanks vela
edit: so then its 12...
if i take the top and bottom its 16!
thanks again
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
13K
