Volume/Volume %, manipulating units
  • Thread starter Thread starter susan__t
    Units
To determine the volume/volume percentage of acetic acid in vinegar, the concentration of acetic acid in mol/L needs to be converted into grams per 100 mL, using the density of acetic acid and vinegar. The user has concentrations of acetic acid in both the vinegar and a diluted sample, which complicates identifying the total volumes of A (acetic acid) and A+B (total solution). It is crucial to clarify that A represents the volume of acetic acid in the original vinegar, while A+B includes the volume of acetic acid in the diluted sample. The conversion from mol/L to grams/L is essential for calculating the final volume/volume percentage. Accurate calculations will provide the desired percentage of acetic acid in the vinegar solution.
susan__t
I am trying to find % acetic acid by volume in vinegar.
I have 8*10-4 mol/L of acetic acid in vinegar and 8*10-5 of acetic acid in the dilute sample of vinegar and water.
I know that the volume/volume % is equal to the amounts of A divided by the total amounts of A and B. BUT that they also should be in mL, considering the density (the assumed density) of water, vinegar and acetic acid is 1.00g/mL.
So I'm having trouble with finding out how to convert the mol/L into just mL. Also having trouble figuring out what A and A+B are. I am assuming A is the volume of acetic acid in vinegar and A+B is the volume of acetic acid in the dilute sample?
Thanks
mol/L can be converted into grams/L which can be converted into grams/100mL.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
