Vonmises Stress Vs Maximum Principle Stress
The discussion clarifies the differences between Von Mises Stress and Maximum Principal Stress criteria in material failure analysis. Maximum Principal Stress theory is applicable mainly to brittle materials like cast iron, predicting failure when the maximum principal stress reaches the elastic limit. In contrast, Von Mises Stress, which focuses on distortion energy, is more relevant for ductile materials, indicating yield when distortion energy exceeds the yield point from tensile tests. The conversation also highlights that Von Mises stress is generally lower than maximum principal stress but is crucial for assessing shear loads in design. Understanding these criteria is essential for accurate predictions of material behavior under stress.
Chandrakiran
Hello All,
Can anyone let me know the difference between Vonmises Stress criterion and Maximum Principle Stress criterion ?? And for what kind of materials " Brittle / Ductile " can they be used and why ??
Thanks in advance for your time.
Maximum Principle Stress Theory - According to this theory failure will occur when the maximum principal stress in a system reaches the value of the maximum stress at elastic limit in simple tension. This theory is approximately correct for cast iron and brittle materials generally.
Source: http://www.roymech.co.uk/Useful_Tables/Mechanics/stress.html
Von Mises Stress (Distortion Energy Theory) - This theory proposes that the total strain energy can be separated into two components: the volumetric (hydrostatic) strain energy and the shape (distortion or shear) strain energy. It is proposed that yield occurs when the distortion component exceeds that at the yield point for a simple tensile test.
Source: http://en.wikipedia.org/wiki/Yield_(engineering )
More information on Von Mises Stress can be found http://en.wikipedia.org/wiki/Von_Mises_stress" .
General information on solid mechanics can be found http://en.wikibooks.org/wiki/Solid_Mechanics" .
CS
HI,
Thank you very much for very useful information and your precious time.
Chandra.
CS
Hi all,
with regards to the max. principal stress vs von mises stress, does a material yield or fail if the von mises is greater than the max. principal stress or visa versa?
secondly, how is the von mises related to compressive strength (or minimun principal stress)?
your help will be greatly appreciated
regards
Tach
Tach159 said:
Hi all,
regards
Tach
The beauty of Von Mises stress is that in the real world "everything" fails by shear. That's why it has emerged as the favorite failure theory. Having said that, the world of material failure is highly stochastic - subject to statistical variation. So as good as the theory is, you still need significant factors of safety if you don't want your project to come crashing down.
You find Von Mises stress from the principle stresses by using a big ol gnarly equation or three. It is always a smaller value than maximum principle stress (by definition) BUT it is aligned in the direction that has to support the maximum shear load. This can be very helpful in design.
hth (and i hope that I'm not too rusty on this subject)
Likes gedw
This is an old thread.
What is the interest in revival?
A question was asked, I assumed it was cool to answer it. Silly me.
It would have been better to start a new thread?
Likes gedw
