- Messages
- 4,949
- Reaction score
- 1,576
Post # please....
The point tto point voltage is indeterminate and you do need to know where your test leads run.Averagesupernova said:I find this quite ridiculous. I can't decide which is more absurd. If the claim is the voltage at the probe points really is indeterminate or if it boils down to an argument about which way the test leads should run and then knowing what to add or subtract (or not) to the reading.
My drawing doesn't match up to what I described in 101, true. It actually doesn't matter, but you would measure the same reading if the leads always ran parallel to the resistor wire (see below).Btw, they aren't drawn that way in your drawings.
Yeah you've mentioned the voltage source / tiny batteries in the wires before. It's pure fantasy. A resistor is a resistor, it dissipates energy, that's it. The emf comes from the electric field induced by the solenoid, per Maxwell-Faraday. It's an outside source of energy. Therefore we do not model any voltage source in the circuit. Why RSD Academy describes it like this, I have no idea. He's trying to have his cake and eat it too - as far as I can tell he's using the more familiar path voltage, but invents a voltage source in the wires to makes things come out to zero. If he was actually using the scalar potential (per McDonald's paper which he cites), he would say so instead of making up ridiculous explanations.The resistor wire is in the field also and is part of the loop that is generating the 12 volts. In the exact same space it also dissipates it. This is modeled as a voltage source in series with a resistance. The RSD academy video I linked to earlier in this thread covers that quite well.
All I'm trying to do was explore the implications of the different conventions. But the 'electrical guy' keeps derailing with objections.hutchphd said:I have lost the trace of rational thought on this thread. I don't even know what the question is......
No. There is no "right" or "wrong" way to measure them because they are not defined If you are in a rabbit hole just stop digging. One must specify the exact path along which to consider the EMF (in practice this will specify where to run the "voltmeter" wires).Averagesupernova said:There is disagreement, in this thread as well as others, whether these voltages of the secondary winding(s) each consisting of a half a turn of wire can be measured. This is a completely new rabbit hole. My view is the Mr. @mabilde did it right in his video.
I do not find the posts by @Dale . Can you give specific reference? I value his opinion.Averagesupernova said:The posts made by @Dale was an eye opener for me as to why I've had such trouble getting my point across.
@tedward you didn't follow this or you didn't pay attention. I'll cut and paste it here for Pete sake.Averagesupernova said:@tedward have a look at the link below. Specifically part way down where it's says: "The three assumptions of CA."
Circuit analysis is all that's needed to make sense of this issue. Naturally we need to know that induction is possible but very little more is needed to understand what's happening here.
https://www.physicsforums.com/insights/circuit-analysis-assumptions/
The implications are: No electric fields. No magnetic fields. No electric charges. Kirchoff’s Laws apply instantaneously around the entire circuit, so there is no temporal first-next ordering of events.
