Warp Drive = Artificial Gravity?
5 replies · 4K views
Deleted member 690984
I had a bit of a brainwave regarding artificial gravity (outside of rotation or linear acceleration). As we know "gravity plating" is just a plot device to allow sci-fi films and shows to escape the pain of having to accurately recreate a zero-g environment. But then I thought: gravity is a deformation, a warping, of space-time, and something like the Alcubierre drive works the same way, it warps space-time.
Purely for the purposes of science-fiction but keeping it somewhat grounded in the realm of reality, could the same principle be used to create artificial gravity? I'm thinking for something like this to be believable, it would have to be an underslung generator if your craft is more traditionally-shaped, or shaped like the ships in something like Star Trek or Star Wars; or at the bottom of the craft if you go with a design like they have in The Expanse, where the vessels are basically skyscrapers in space.
What do you think?
on Phys.org
Artificial gravity is created by creating an acceleration felt by the observer. It a rocket ship that is accelerating at 1 g or more preferred a ring that revolves at a certain rotational speed that you can stand in Allowing the spaceship to travel at any constant speed.
Warp speed refers to a means to travel faster than light which in our current understanding is not possible.
The movie 2001 A Space Odyssey had a scene with a rotating ring where astronauts worked and exercised.
Other Sci-fi tropes include the use of magnetic boots that keep you from floating freely but isn’t really artificial gravity.
Postulating gravity plating as a means to provide artificial gravity is possible but you’ll need to consider its pros and cons like maybe in the presence of a gravitational field it begins to act wonky or maybe it affects the ships propulsion when near a gravitational field like a magnet attracts or repels another magnet. These pros and cons can be written into your story in interesting ways.
Thank you for your reply, but that's not what I was asking. I was asking since warp drive and gravity both work in very similar ways (by warping space-time), would it be believable for a science-fiction story to have a gravity generator behave in a similar way, i.e. by warping the local space-time around the ship and creating a gravity well.
The problem with warp drives is that they require negative energy densities which may or may not be nonsense.
If you've got one in your story, though, I'd put positive energy density generators in the floor and negative energy density generators in the ceiling. Then you could argue that you've got a total energy density (and hence mass density) of zero, so it doesn't affect manoeuvring, and the plate pairs form a dipole, which has a short ranged field and explains why your ship's gravity doesn't pull passing asteroids out of orbit.
That's still nonsense for various reasons, but maybe plausible sounding nonsense.
Reply
Perfect! Thank you.
Would this concept be applicable for colonial habitats? I'm thinking if a colony was constructed on the surface of, say, Mimas, which has a surface gravity of 0.00648gs, would this concept affect the geology of whatever the colony is built upon, or would the same principle apply regarding the short-ranged field?
