MHB Why Does Cyclohexane Float on Water When Its Molecular Mass is Higher?
  • Thread starter Thread starter markosheehan
    Water
Cyclohexane floats on water due to its lower density, despite having a higher molecular mass. Water's molecular structure allows for strong hydrogen bonding, resulting in a higher density compared to cyclohexane. The density of water is approximately 1 g/cm³, while cyclohexane has a density of about 0.79 g/cm³. This difference in density is the primary reason cyclohexane remains on the surface of water. Understanding these properties is crucial for grasping the behavior of different substances in mixtures.
markosheehan
Why does cyclohexane float on water.? When I add up their relative molecular masses water has a lower value than cyclohexane?
Mathematics news on Phys.org
Floating occurs when the mass density is lower.
So even though water consists of smaller molecules with less mass (10 versus 84 g/mol), water still has a greater density.
What could the difference be?
For the record, this topic also came up in http://mathhelpboards.com/other-topics-22/ethanol-water-21217.html of yours.
its to do with the hydrogen bonding .
thanks
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
