Renie
- 3
- 0
Hi
I need help calculating water flow through a few tee pipes.
Water flows to the plant through a 36” diameter pipe @3500m3/h and 220kPa for 9m before teeing out to a 24’’ pipe (1.5m high with butterfly valve). The original 36’’ than immediately encounters a 90 degree bend before it is reduced to a diameter of 24’’. The water flows from the bend for another 10 meter before reaching another t pipe which is 12’’ in diameter and for 2m teeing into a16’’ diameter pipe(1.5m high with butterfly valve) . After another 6m it ties out to an 8’’ pipe level @1.5m long (with butterfly valve). The 8’’ pipe that elevates to a height of 20m going to a Nitrogen /water tower. The rest of the water that came from the original 36’’ pipe flows through an 8’’ plant to the rest of the plant
I need to calculate the flow of water to each tee pipe in order to get the water flow to Nitrogen/Water tower to do an efficiency calculation
Thanks
Thanks
