How to Calculate Electrical Power from Water Flow Rate?
The discussion focuses on calculating electrical power output from water flow rate using a turbine connected to a pipe. Key concepts include Bernoulli's principle, which relates potential energy, kinetic energy, and pressure energy. The mass flow rate is defined as dm/dt = ρ dV/dt = ρ v A, where v is the flow velocity, ρ is the water density, and A is the pipe cross-sectional area. Participants emphasize the importance of knowing the total head, pipe diameter, and turbine type for accurate calculations.
  • Understanding of Bernoulli's principle
  • Knowledge of mass flow rate calculations
  • Familiarity with different types of turbines (e.g., Turgo, Pelton, Kaplan)
  • Basic principles of fluid dynamics
  • Research how to calculate total head in hydraulic systems
  • Learn about the efficiency of different turbine types
  • Explore the relationship between flow rate and pipe diameter
  • Study energy conversion principles in hydroelectric systems
Engineering students, electrical engineers, and anyone involved in renewable energy projects, particularly those focusing on hydroelectric power generation.
calbolan
Hi,
Me and 4 others are stumped on our HNC Electrical Project. We need an equation that calculates from the flow rate of water and diameter of a pipe, what amount of electrical power outage can be gotten by using a simple turbine connected to the pipe.
Any sort of help would be greatly appreciated as we are more than struggling with the whole of this project.
Regards,
Cal
I guess Bernoulli's principle could be a starting point if velocity is required...
It states that the sum of the potential energy, kinetic energy and the pressure energy is constant...
So:
\frac{1}{2}mv2 + mgh + PV = constant
So, if the initial energy be known, we can compute the velocity and hence the rate at which the water is flowing.
Mass flow rate = dm/dt = ρ dV/dt = ρ v A, solve for v.
v = flow velocity along pipe in m/s
ρ = density, kg/m^3
A = pipe area in m^2
dm/dt = mass flow rate in kg/s
dV/dt = volumetric flow rate in m^3/s = vA
So in 1s the delivered K.E. would be 1/2 dm/dt v^2
Make sense? Not my main field but seems straightforward.
calbolan said:
Hi,
Regards,
Cal
Hey Cal,
Per the forum rules, I can not offer any help without proof that you've attempted to figure it out on your own. Perhaps you can share some specific details about your inquiry and particular steps you've taken to solve your question?
What is the total head?
Pipe ID?
Pipe length?
Simple turbine? What kind? Turgo, Pelton, Kaplan, Banki... Water wheel?
  • · Replies 16 ·
