Why does water spin in different directions at different parts of the world?
Water spins in different directions in the Northern and Southern Hemispheres due to the Coriolis effect, which is a result of the Earth's rotation and spherical shape. This phenomenon is often misinterpreted in everyday situations like water draining, as it does not consistently dictate the direction of water flow in sinks or toilets. Instead, the Coriolis effect is more prominently observed in large-scale weather patterns, such as hurricanes. At the equator, the Coriolis effect is negligible, meaning water does not spin in a particular direction.
Jack
Also, which way does it spin on the equator?
If you are talking about the idea that water going down a drain in the Northern Hemisphere spins one direction and water the the Southern Hemisphere in the Other, It doesn't.
The Idea come from the fact that hurricanes follow this pattern. The reason for this behavior is The Coroilis effect.
The Coroilis effect is caused by the fact that the Earth is spinning and shaped like a sphere.
check out the following links:
http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html
http://math.ucr.edu/home/baez/physi...al/bathtub.html
Oh, but in X-Files it does
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
