Wave function/Infinite square well confusion
3 replies · 7K views
Salviati
"A particle of mass m is in the ground state of a one-dimensional infinite square well with walls at x=0 and x=a.
[tex]\psi_1(x) =\sqrt{\frac{2}{a}}sin(\frac{\pi x}{a})[/tex],
E1=[tex]\frac{h^2\pi ^2}{2ma^2}[/tex]*
What is the initial wave function [tex]\Psi(x,0)?[/tex]
*[tex]h[/tex] is supposed to be h bar, I just couldn't find it)
My attempt: If the general solution is a superposition of all stationary states, [tex]\Psi(x,t)=\sum c_n\psi_ne^\frac{-iE_nt}{h}[/tex], at t=0, [tex]\Psi(x,0)=\sum c_n\psi_n[/tex]. Also, at this time, the particle is in the ground state (n=1), so: [tex]\Psi(x,0)=c_1\psi_1[/tex]. Do I assume c1=1 at this point, because the wave function "collapses" once the energy becomes known? I'm just not sure if I understand exactly what happens when the known data is given.
The solution itself is supposed to be [tex]\Psi(x,0)=\psi_1(x) =\sqrt{\frac{2}{a}}sin(\frac{\pi x}{a})[/tex].
c1=1 by normalization, assuming that [tex]\Psi(x,t)[/tex] is normalized. For a more general initial state,
[tex]\sum_{n=1}^\infty |c_n|^2=1.[/tex]
You are right to be confused. You cannot know the answer to this question; that is the whole idea behind boundary conditions/initial values: they are INPUTS. For a first-order differential equation (like (d/dt)psi=iHpsi), you need one input BC for each degree of freedom.
Try \hbar.
Thanks guys.
turin said:
Try \hbar.
[tex]\hbar[/tex] :redface:
