Wave Motion, writing an equation.
The discussion focuses on deriving the wave function for a sinusoidal wave traveling in the -x direction with specified parameters: amplitude of 20.0 cm, wavelength of 29.0 cm, and frequency of 15.0 Hz. The correct wave function is determined to be y(x,t) = 20.0 sin(0.217x + 94.25t - 0.1506), incorporating a phase constant to satisfy the initial condition of y = -3.00 cm at t = 0 and x = 0. The participants confirm the necessity of using sine instead of cosine for the wave function to align with the given conditions.
  • Understanding of wave mechanics and sinusoidal functions
  • Familiarity with wave parameters: amplitude, wavelength, and frequency
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to manipulate equations involving angular frequency and wave numbers
  • Study the derivation of wave functions in different directions, specifically for waves traveling to the left and right
  • Learn about phase constants and their significance in wave equations
  • Explore the relationship between wave speed, frequency, and wavelength using the equation v = λf
  • Investigate the use of sine and cosine functions in modeling periodic phenomena
Students studying physics, particularly those focusing on wave motion, as well as educators and anyone interested in understanding the mathematical representation of waves.
Ithryndil
A sinusoidal wave traveling in the -x direction (to the left) has an amplitude of 20.0 cm, a wavelength of 29.0 cm, and a frequency of 15.0 Hz. The transverse position of an element of the medium at t = 0, x = 0 is y = -3.00 cm, and the element has a positive velocity here.
Write an expression for the wave function y(x,t), where y and x are expressed in cm, and t is expressed in seconds.
\omega = 2\pif
v=(lambda)(frequency)
k = 2\pi/\lambda
y(x,t) = Asin[\left(2\pi/\lambda\right)(x - vt)]
We are given the fact that:
A = 20.0cm
\lambda = 29cm
v = (lambda)(frequency) = 435cm/s
I think the answer is the following, but I am not sure, and I only have one more submission left, so I want to be sure.
y(x,t) = -20.0cos[.217(x-435t)]
Anyone have any idea if I am correct?
Hi Ithryndil,
If you check your answer at x=0 and t=0, you get that y=-20 cm. However, this is not what the problem specifies; they say they want x==-3cm at x=0 and t=0.
I think you need to include a phase constant in your expression that will give the correct initial condition.
You mean y = 3 cm? And I think so too. I just realized that the general equation for y(x,t) is as follows:
<br /> y(x,t) = Asin(kx - vt + \phi)]<br />
I think the above equation is for a wave traveling to the right. I think because this wave is traveling to the left it needs to be:
<br /> y(x,t) = Asin(kx + vt + \phi)]<br />
Yes, I did mean y= -3 cm. Sorry!
Your updated equation looks good. Once you plug in the numbers you found, you can check that it matches y=-3cm at x=0 and t=0 and that it also has a positive velocity (in the y direction at that point).
Alright, thank you for the help.
Ithryndil said:
<br /> y(x,t) = A\sin(kx + vt + \phi)]<br />
That is almost correct. There should either be some more parentheses inside the sin argument, or replace vt with \omega t.
You're right, it should be: y(x,t) = A\sin(kx + \omegat + \phi)
I wound up getting the following for the equation:
y(x,t)20.0sin(0.217x+94.25t-0.1506)
Now I was stupid and input y(x,t)20.0cos(0.217x+94.25t-0.1506)...note I put cosine and not sine. Yes, the cosine would be correct with the right phase angle, but it's not with that phase angle.
Your expression (using sin) looks good. :smile:
Thank you. I just can't believe I inputted the expression with cos instead of sin.
