Wavelength of Light: 0.544µm in Air & Water
  • Thread starter Thread starter Kickbladesama
    Light Wavelength
Light with a wavelength of 0.544 µm in air enters water, where its speed is 0.700 times that in air. The correct approach to find the wavelength in water involves understanding that the frequency of light remains constant across different media. The speed of light in a vacuum is approximately 3 x 10^8 m/s, and the relationship between speed, wavelength, and frequency is given by the equation v = fλ. By applying these principles, one can calculate the new wavelength of light in water. Understanding the underlying physics concepts is crucial for solving such problems effectively.
Kickbladesama
Light of wavelength 0.544 µm (in air) enters the water in a swimming pool. The speed of light in water is 0.700 times the speed in air. What is the wavelength of the light in water?
mu = m / L
v = sqrt (F/mu)
speed of air 386 m/s
0.700 x 386 = 270.2
270.2 = sqrt (F / 0.544) = 39716.40
F = 39716.40
idk what to do now
The equations you are using do not apply to light waves. Your formula for a velocity is for a mechanical wave on a string, not a light wave. 386m/s is NOT the speed of light in air, not even close.
Forgive me if I'm wrong, but it seems you are trying to plug and chug equations to get an answer for this problem without even considering what the equations mean. You have to go and seriously read the chapter on this topic in your book if you haven't done so. Trying to mindlessly plug an chug equations is a recipe for disaster in a physics course.
I will give you a few hints to get you on the right path:
The speed of light is related to the light's wavelength and frequency by:
\lambda f=v
The speed of the light depends on the medium and is given by:
v=c/n, where n is the index of refraction of the medium.
c is the speed of light in a vacuum:
c=\lambda_{vac}f=3*10^8 m/s
The frequency of the light will remain the same in all media.
Using this information, can you solve the problem?
thanks for help
how do i do this problem?
As GO1 said, use the relation between wavelength, frequency, and speed:
f = v/λ
And this:
Using the fact that f is the same for the light in air or water, work with the above equation.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
