B We could lose electricity and satellites due to solar flares
Solar flares pose a potential threat to Earth, with scientists predicting significant impacts within the next century. The estimated repair costs in the U.S. could reach up to $2.5 trillion if a major solar event occurs. While solar flares are common, the concern centers on the severity of a large flare, which is less frequent. Accurate understanding and communication of these risks are crucial for preparedness. The discussion highlights the need for awareness of solar activity and its implications for technology and infrastructure.
ianz1234
Hello, all!
I found several sources which say that humanity could be in trouble because of solar flares! Scientists said that the Earth could be hit by solar flare within the next 100 years!
Current costs of repair in the US could be up to 2.5 trillion dollars!
It seems like Sun will punish the Earth
Source: Solar flare threats
Astronomy news on Phys.org
ianz1234 said:
Hello, all!
Yes. So? This has been known for quite a while.
Also, "the Earth could be hit by solar flare within the next 100 years!" is a bit naive. We are often hit by solar flares. What matters is how big it is. You are talking about a BIG solar flare, which is relatively infrequent.
Likes davenn
ianz1234 said:
Hello, all!
you would do well to read the article more carefully, and if you are really going to quote from it,
then you should do that accurately and not in your own words which were incorrect :wink:
@phinds has given you a good response :smile:
Dave
Likes phinds
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
Both have short pulses of emission and a wide spectral bandwidth, covering a wide variety of frequencies: "Fast Radio Bursts (FRBs) are detected over a wide range of radio frequencies, including frequencies around 1400 MHz, but have also been detected at lower frequencies, particularly in the 400–800 MHz range. Russian astronomers recently detected a powerful burst at 111 MHz, expanding our understanding of the FRB range. Frequency Ranges: 1400 MHz: Many of the known FRBs have been detected...
32K
10K
