What Is the pH at Equivalence for a Weak Acid-Strong Base Titration?
In a titration of 25 mL of 0.1 M acetic acid (HOAc) with 0.15 M sodium hydroxide (NaOH), the pH at equivalence will be greater than 7 due to the weak acid-strong base reaction. To find the exact pH at equivalence, one must first calculate the moles of NaOH required, using stoichiometric relationships from the balanced chemical equation. The resulting solution at equivalence will contain sodium acetate, the conjugate base of acetic acid. The pH can then be determined by using the Kb of sodium acetate. This approach allows for an accurate calculation of the pH at the equivalence point.
monae
25 mL of 0.1 M HOAc are titrated with 0.15 M NaOH. What is the pH at
equivalence?
I know that the pH at start will be greater than 1.0 and the pH at equivalence will be greater than 7 since its a titration of a weak acid and a strong base. But what I don't know is whether or not there is a way to solve this problem for the exact pH since the volume of NaOH is not given.
can't you figure out the volume of NaOH, though?
write and balance the chemical eqn, and then use stoichiometric relationships to find the moles of NaOH. Divide this by the molarity (0.15 M) to get milliliters of NaOH.
equivalence?
The pH at equivalence point is the same as solution containing the equivalent concentration of sodium OAc. You can use the Kb of this conjugate base of the weak acid.
