Weight-activated switch circuit design
5 replies · 3K views · last reply
Tahmeed
I am designing a circuit, in this simple circuit, when a weight isn't applied, the switch will go off and the circuit won't work until a certain weight is applied, how can i design it?? i am totally new and doing this for a science club, i have never designed any circuits with censor. so please be elaborate in your description, if possible, please give a simple drawing of a possible design and i will modify it according to my need.
Thanks.
Thanks.
Try doing a Google Images search on Limit Switch:
http://3.imimg.com/data3/YP/XH/MY-3059229/limit-switch-250x250.jpg
Photo of a small black microswitch with a metal lever arm extending from the top and three flat metal terminal pins projecting from the front, two with mounting holes beside them.
You could improve the Google Images search by adding the term Circuit to the end of it to get some typical schematics...
:smile:
Weight is force.
One can buy force sensors.
Force will compress or stretch a spring, changing force into movement.
You could detect movement with a switch like the picture above
or with the optical wheel sensor from a junkshop computer mouse
to change force into movement with some accuracy,,
check out Hooke's Law
http://www.britannica.com/science/Hookes-law
jim hardy said:
Weight is force.
yup, commonly called Load CellsDave
There are many approaches, some alluded to above. It depends a lot on your mechanical constraints, which you have not been clear about. Are you allowed to have something move, or does it have to be an essentially solid/steady platform? If it can move, how much?
Putting rocks in a basket connected to a spring is a different problem from putting rocks on a tabletop that is essentially solid. Or are you pouring water is a bucket? Adding people to a platform? We have no idea.
But is does boil down to either:
a load cell (or strain gauge) that drives a detection circuit. This requires a load cell amplifier and comparator to drive a relay or something. Probably not what you want.
OR
a switch (mechanical or optical) that detects spring displacement (or the like).
