Weight and the Archimedes Principle
The discussion revolves around the implications of Archimedes' Principle and buoyancy, particularly focusing on the weight of a container of water when a hollow, buoyant object is submerged and then released. Participants explore the relationship between displaced water, the forces involved, and how these affect the weight readings on a scale.
  • Some participants propose that when a buoyant object is pushed to the bottom of a container, the container's weight increases due to the displaced water.
  • Others question what adds weight in this scenario, particularly when considering a weightless object tethered to a weightless container filled with water.
  • A few participants argue that the force applied to push the object down is what causes the weight to increase, rather than the weight of the displaced water itself.
  • There is a suggestion that once the object is released, the scale will show less weight as the object floats to the surface.
  • Some participants discuss the difference between weight and pressure, noting that while pressure may change, the overall weight remains constant regardless of the container's shape.
  • One participant highlights that the discussion involves a transient state far from equilibrium, complicating the understanding of buoyancy and weight measurements.
Participants express multiple competing views regarding the relationship between buoyancy, displacement, and weight. There is no consensus on what specifically causes the weight change when the object is submerged or released.
Limitations include varying definitions of weight, assumptions about the system's equilibrium, and the effects of transient forces during the process of submerging and releasing the object.
gloo
I was wondering - if you had a container of water and you push a hollow object that is buoyant to the bottom so that it is completely immersed - the whole container will be heavier because of water being displaced up in the container.
Now if you release your hand or whatever you use to hold the object down near the bottom -- the object will float up. But is the container still heavier in the time interval that the object is still completely immersed? I am assuming yes because the amount of water displaced up is still the same and the hollow object is not attached to the container but freely moving up in the water.
Uh ... it will? What is adding the weight? What would happen if you STARTED with a weightless hollow object tethered to the bottom of a weightless container and then filled the container with 10lbs of water that went up over the top of the object. What would the container weigh? In other words, I ask again,what is it that adds weight in the first case? Is any weight added in my scenario? Why or why not?
If tethered to the bottom it will weight the same since it is now part of the system. But my scenario is that it is not attached to the container but in the midst of floating to the top - but still submerged. The submerged object will still have displaced a volume of water up.
You have not answered my question.
Ignoring the weight of the container it would weight less than 10 pounds I am assuming because the water spilled over the top and does not weigh down on the container anymore.
Sorry, I thought you said it would flow out of the container. Ignoring the weight of the container it would be 10 pounds - the weight of the water because the object that is buoyant is tetthered to the bottom
You are NOT answering my question. WHAT CAUSES THE EXTRA WEIGHT in your scenario?
1. In your case with the teeter - no weight is added
2. the weight added in the first place (my scenario) - was my force pushing the hollow object down which then displaces the water higher. My force is causing the water to displace up
3. No weight is added in your scenario because you tethered the hollow object to the container and is now part of the container system
Back up. Before you start arguing about what causes the extra weight you should define what you mean by the word "weight".
The way the rest of us use it, it is the downward force of gravity on an object and NOT the upward force required to hold an object in position against a sales clerk with his thumb on the scale.
http://www.saturdayeveningpost.com/...nd-the-canvas-art-entertainment/rockwell.html
And what happens when you stop pushing down?
the object will start to move up to the surface
What happens on the SCALE ? That's what your original question was about
The scale will show less weight once the object is floating on top of the surface
What I have been trying to help you see is that it is not the weight of the displaced water that causes the scale to show a larger value when you press a lighter-than-water object into it, it is the force you have added by pushing the weight. When you release the weight you are no longer adding any force and so the system now acts exactly as it would if the object were tethered to the water level. It becomes irrelevant whether the object is under the water or floating on top of it.
Thread locked for moderation.
Can we all just get along? Thread reopened.
Buoyancy is all about hydrostatics -- equilibrium situations. The questioner here is asking about a transient state in which the system is far from equilibrium. The answer is unlikely to be obvious. [or even unambiguous]
So is my thinking straight on this aspect of the question -
We place a shallow pan on a scale, then add one liter of water. We expect the scale reading to increase by ~ 1 kg (within the accuracy of the scale, our volume measurement, purity of water, temperature, etc).
We remove that container, then place a very tall container on the scale, then add one liter of water. I think we could expect the scale to read a bit more than 1 kg weight (assuming the scale would have enough sensitivity/resolution). The water in a tall column provides more downward force, just like the water in a municipal water tower. Correct?
The mass has not changed, only our measured weights.
edit - wait, the pressure/area is higher, but the area is less. So no change in weight?
No change in weight. :)
You are confusing water pressure w/ weight. As Drakkith said, no change in weight
Yes, thanks, I see that now (and was pretty sure I figured it out just after I posted - see my edit).
There will be small transitional forces on the scale during the process. Ignore the force involved in removing your finger (perhaps use an infinitely thin rod to push it down). When you first release the object, the recorded weight will be Weight of Bowl, water and object. The object will then accelerate upwards until it reaches a terminal velocity. That will temporarily increase the force on the scale. Likewise, when the object reaches the top, it will slow down and the recorded weight will dip for a short while until the total weight is Bowl, water and object again. Depending upon the damping coefficient, there could be a number of cycles of variation of recorded weight whilst the object 'bobs' up and down a bit.
I believe that you have this backward. The object accelerates upward only because the water is accelerating downward. The net effect is to temporarily reduce the force on the scale.
Agreed, and I think this is the important part. There will be oscillations.
Ummm. Yes. I think you are right to challenge it. There is a greater mass of water accelerating downwards than of object rising so perhaps the 'weight would appear to be less'. If it were a bubble, the rising mass would be negligible so it would be the equivalent of the whole mass of water falling to fill the space. Question is whether this reduction applies as the object (/bubble) continues rising or is it just at the start? I think it must apply just at the start because acceleration stops fairly quickly.
Any more ideas, anyone?
  • · Replies 29 ·
  • · Replies 34 ·
  • · Replies 35 ·
