What angle should a swimmer aim to land directly across the starting position?
The problem involves a swimmer crossing a river with a current, aiming to determine the angle at which to swim in order to land directly across from the starting position. The subject area includes kinematics and vector analysis related to motion in a fluid medium.
  • Mixed
  • Participants discuss the swimmer's speed in still water and the downstream drift caused by the river's current. There are attempts to calculate the necessary angle to swim upstream to counteract the current, with varying results and methods presented. Some participants question the assumptions made regarding the relationship between the swimmer's trajectory and the current.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided calculations and reasoning, while others have raised questions about the assumptions and methods used. There is no explicit consensus on the correct angle, and multiple perspectives are being considered.
Participants note potential discrepancies between their calculations and the textbook answer, suggesting that different interpretations of the angle measurement may be influencing their results. There is also mention of the time taken to cross the river and how it affects the downstream drift.
WorkingHard2017
A swimmer who achieves a speed of of 0.75 m/s in still water swims directly across a river 72m wide. The swimmer lands on the far shore at a position 54m downstream from the starting point. Determine the direction the swimmer would have the aim to land directly across from the starting position
v swimmer relative to ground = v swimmer relative to water + v water relative to ground
v water relative to ground = 0.56 m/s[/B]
tanθ = (0.56/0.75)
θ = 37° downstream from the starting position
so to land directly across the starting point, the swimmer would need to aim 37° upstream from the starting position. Is this correct? My book says 42° upstream from the starting position, but I can't see how that makes sense.
Please explain your working. How do you get this:
Actually, you do not need to know any speeds. The two distances are enough information.
(I'm getting 49 degrees.)
I wonder if the book is considering the angle to be between the shoreline and the swimmer's trajectory?
That's probably the explanation, though for that I make it much closer to 41 degrees.
Hi there, so to get 0.56 m/s, I determined that since the swimmer travels 0.75 m/s, he would travel 72m in 96s. From there, I divided the length of the river, (54m) by 96s to get a speed of 0.56m/s.
Could you please explain how you came about that answer?
Ok. Your error is in assuming that the angle that the swimmer gets carried downstream when swimming straight across relative to the water is the same as the angle the swimmer has to aim upstream. E.g. when aiming upstream the time taken to cross increases, so the current gets to carry the swimmer further.
Draw the right-angled vector triangle for the swimming upstream case. Which side represents the swimmer's velocity relative to the water and which side the current?
