What Are Fractional Roots and Why Do They Confuse?
  • Thread starter Thread starter W3bbo
    Fractions Roots
Fractional roots can be confusing due to the complexities of simplifying expressions, particularly when square roots are involved. A specific example discussed involves the expression {{{(1 + \sqrt{2}) / \sqrt{2}} / {(1 - \sqrt{2}) / \sqrt{2}}}, which leads to differing results based on how the calculations are performed. Missteps in distribution and term arrangement in the denominator can lead to incorrect conclusions. Additionally, a related question about transforming a differential equation expression highlights the importance of understanding the manipulation of fractions and signs. Overall, careful attention to detail in calculations is crucial for accurate results in mathematical expressions.
W3bbo
Starting with simple fractions, it's known that:
{{{a \over b}} \over {{c \over d}}} = {{ad} \over {bc}}
So when b == d:
{{{a \over b}} \over {{c \over b}}} = {a \over c}
But what if in the case of:
{{{{1 + \sqrt 2 } \over {\sqrt 2 }}} \over {{{1 - \sqrt 2 } \over {\sqrt 2 }}}}
Following the above (for abc), it should result in:
{{1 + \sqrt 2 } \over {1 - \sqrt 2 }}
But if you follow the abcd version:
{{\left( {1 + \sqrt 2 } \right)\sqrt 2 } \over {\sqrt 2 \left( {1 - \sqrt 2 } \right)}} = {{2 + \sqrt 2 } \over {2 - \sqrt 2 }}
...which is not equal to the first expression.
Why?
Mathematics news on Phys.org
Why?
Are you sure that you did the calculations right, at frist place?
Check your work, you did not distrubute correctly the \sqrt{2}
remember \sqrt{2}*\sqrt{2}=2 \ \ \ and \ \ \ not \ \ \ \sqrt{2}
Yes.
\displaylines{<br /> \sqrt 2 \left( {1 + \sqrt 2 } \right) = \left( {\sqrt 2 \times 1} \right) + \left( {\sqrt 2 \times \sqrt 2 } \right) \cr <br /> = \sqrt 2 + 2 \cr}
W3bbo said:
Yes.
Check the denominator, too.
You got the terms reversed in the demoninator: {{\left( {1 + \sqrt 2 } \right)\sqrt 2 } \over {\sqrt 2 \left( {1 - \sqrt 2 } \right)}} = {{2 + \sqrt 2 } \over {2 - \sqrt 2 }}
Denominator should be \sqrt{2}-2
Ah, that solves it then. Thanks.
As an aside, how can I make this:
{{dy} \over {dx}} = {{2y - x^2 } \over {y^2 - 2x}}
into this:
{{dy} \over {dx}} = {{x^2 -2y } \over {2x - y^2}}
They're meant to be identical, but I can't think how.
Thanks!
into this:
Thanks!
multiply the top and the bottom by -1.
You can do this because in essence it is multiplying the entire expression by 1.
into this:
Thanks!
Are you working on diff. eq. or someone just gave u that expression. Don't tell me that you are!
It's part of a larger exercise on a differential equation. Just a simple example for an implicit function.
This was something that i really was affraid i would hear. Damn.!
