What Are the Tension Forces in Suspended Structures?
  • Thread starter Thread starter cary1234
    Tension
The discussion focuses on calculating tension forces in various suspended structures, specifically involving free body diagrams for different scenarios. Participants are asked to analyze figures depicting a suspended crate, a horizontal beam, and a uniform rod with a hanging monkey. The user has attempted to draw free body diagrams for the first two questions but is uncertain about the third. There is a request for assistance in verifying calculations and drawing accurate diagrams, highlighting a need for collaborative problem-solving in physics.
cary1234
Please help me to draw free body diagrams of the following.
1.Find the tension T in each cable and the magnitude and direction of the force exerted on the strut by the pivot in each of the arrangements in fig. 11.23 in each case let w be the weight of the suspended crate full of priceless art objects. The strut is uniform and also has weight w.
this is fig. 11.23
http://img191.imageshack.us/img191/2811/physicsforum.th.png
2. The horizontal beam in fig. 11.24 weight 50N. and its center of gravity is at its center.
find
a.The tension in the cable
b.The horizontal and vertical components of the force exerted on the beam at the wall.
this is fig. 11.24
http://img6.imageshack.us/img6/6100/physicsquestion2.th.png
3. A 3.00 m long, 240-N uniform rod at the zoo is held in a horizontal position by two ropes at its end(fig. 11.26) The left ropes make an angle of 150 deg. with the rod and the right rope makes an angle θ with the horizontal. A 90-N howler monkey hangs motionless 0.50 m from the right end of the rod as he carefully studies you. Calculate the tensions in the two ropes and the angle θ
this is fig. 11.26
http://img40.imageshack.us/img40/6250/question3f.th.png
in question number 1. here's the free body diagram.
http://img9.imageshack.us/img9/6702/question1attempt.th.png
in question # 2 here's the free body diagram.
http://img27.imageshack.us/img27/5323/question2attemt.th.png
in question number 3. i don't have any idea...
please try to draw the right free body diagram..
after i know the right free body diagram i will start to work in computation or equations..
i try to solve question number2 and my answer is.
-T1 = 75
T2=60
is it correct?
how sad.. :( no ones helping me..
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
