What are the Three Sources of Red-Shift in Astronomical Observations?
  • Thread starter Thread starter nomadreid
    Red-shift Sources
nomadreid
There appears to be three sources of red-shift: or are there only two, and two of the following are equivalent?
(1) Classical Doppler shift
(2) Relativistic Doppler shift
(3) Red-shifting from the expansion of space
Otherwise put, which ones are calculated for retreating galaxy clusters and the like?
Thanks.
The classical Doppler shift is just the low-velocity approximation to the special-relativistic Doppler shift.
In SR, there is only one kind of Doppler shift, which is the kinematic Doppler shift due to the relative motion of the source and the observer.
In GR, you get both kinematic and gravitational Doppler shifts ( http://en.wikipedia.org/wiki/Pound-Rebka_experiment ).
When you apply GR to cosmology, there is no clear distinction between kinematic and gravitational Doppler shifts. This is because GR doesn't have an unambiguously defined way of defining the relative motion of two objects that are distant from one another. All cosmological redshifts can be interpreted as kinematic or gravitational, or as some combination of those.
There is only one type of redshift. You can split it approximately into different components if you have certain symmetries to exploit.
For example, if you can define reasonably well static coordinates (approximate time-translation symmetry), you speak of gravitational and doppler redshift. (The latter is always the relativistic one).
Or, if you have approximate spatial homogeneity and istotropy, you speak of redshift from the expansion of space and redshift from peculiar motion.
If you have both kind of symmetries, you can use whichever you want. The physics is not different, it's always GR.
Thank you, bcrowell and Ich, for your helpful and quick replies.
Increasingly visible space is necessarily balanced with increasingly transparent/invisible space in astronomical/telescopic observations.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
