What Are the True Dimensions of Time?
  • Context: Graduate
  • Thread starter Thread starter HBar
    Time
The discussion revolves around the nature and dimensions of time, exploring its definition, relativity, and implications in physics. Participants examine time as a dimension, its measurement, and its relationship with speed and motion, incorporating theoretical and conceptual perspectives.
  • Some participants question whether time is merely a dimension or if it encompasses more complex properties.
  • Others propose that time can be defined as a coordinate alongside spatial dimensions, influencing phenomena like aging and decay.
  • A participant suggests that time is a universal invariant that cannot be stopped, while also noting its mathematical applications.
  • There is a discussion on the relativity of time, particularly how it changes with speed, referencing Brian Greene's analogy of velocity and time.
  • Some argue that as an object approaches the speed of light, its progress through time effectively halts, raising questions about the experience of time at luminal speeds.
  • Another viewpoint suggests that time is both relative and quantized, with photons experiencing no passage of time while traveling vast distances.
  • One participant introduces the idea that time may appear different based on one's frame of reference, particularly in extreme conditions like near black holes.
Participants express a range of views on the nature of time, with no consensus reached. Disagreements persist regarding its dimensionality, relativity, and the implications of traveling at or near the speed of light.
Limitations include varying definitions of time, dependence on specific physical theories, and unresolved questions about the implications of time travel and the nature of time at relativistic speeds.
HBar
What is time? I've heard this questions asked many times on other forums, but since they weren't physics forums nobody seemed to be able to offer an answer. I know time is another dimension, but is it merely that? Is it just hard for people to grasp because they can't see it?
-HBar
Time can be considered a dimension in the sense that we define a positional coordinate in our world based on latitude, longitude, and altitude. Well take that a step further and define that coordinate by latitude, longitude, altitude, and moment of existence in time. We observe the effects of time every day; cellular aging, nuclear decay, oxidation of metals. Time is also just a unit of measurement.
Anyone have some other definitions?
This thing all things devours:
Birds, beasts, trees, flowers;
Gnaws iron, bites steel;
Grinds hard stones to meal;
Slays king, ruins town,
And beats high mountain down.
Time
I believe time is a universal inverience, whereby time doesn't stop, you can't force time to stop. We can use time in mathematics e.g. measure time to reach a certain distance. Time can be precise if properly calculated. As far as Time travel, well its theorectical and that we cannot go back because time is erased, its history. But someday we could go forward in time, depending on how the theory is coming along by that time.
But isn't time relative, i.e it changes if you travel at great speeds?
Yes. In fact, there is a very useful analogy which Brian Green uses near the opening of his book "The Elegant Universe". He proposes that it might be useful to think of all material objects as having a total velocity of c. The analogy he uses is that of a car driving across a dry lake bed. On this lake bed there are lines drawn north-to-South. These lines are one kilometer apart. If you drive your car straight eastward, at a speed of 60 kilometers per hour, you will cross one line every minute. But if you turn to the Northeast, at a 45o angle, it will take you two minutes to get from one line to the next. Although your total velocity is still 60 kph, only half of that total velocity is assisting you in your eastward progress.
In the same way (says Green), whenever we move through one of the three "spatial" dimensions, that velocity must be subtracted from our progress through time, so that our total velocity still equals c. If you were to turn your car straight north, you would never reach the next line on the lake bed because 100% of your total velocity would be devoted to NorthWard progress. Likewise, if you accelerate to c in any of the three spatial directions, your progress through time will stop. The next "moment" of your life will never arrive, because you have brought yourself parallel to it.
So, when you are stationary relative to some spatial frame of reference, time passes at lightspeed. When you travel at lightspeed through space, you become stationary relative to time.
Yes Lurch, Brian Greene's The Elegant Universe (I picked it up in a second-hand shop for £3 and though I have already had a formal education in most of the areas he talks of, he really brings SR and GR down to an intutive level)is by and away the best pop-sci book on the subject of physics, it beats the pant's off A Brief History of Time.
The overriding fact about (special) relativity is that you should always remember that the speed of light in a vacuum will appear the same whatever your frame of reference, everything else follows on from this.
Time is the movement of a particle Q from point a to point b, and because it typically happens in 1 second at 78 degrees under a certain gravitation and electromagnetic force we call it one second, all matter influences all matter and so time is variable. In order for one to go back in time all matter would have to take on it's exact opposite characteristics, - would be +, it is more human to want to correct the mistake of the past and make good science fiction.
OMV, as a clock approaches the speed of light the atom in it's spring winding must slow it's internal motion to compensate for increased motion outside and maintain constancy of energy, remember energy can't be created or destroyed and energy has been transferred in motion, as a result the spring metal's atoms interact and move slower and the clock hand moves slower and time seems to slow down except if you are traveling with the clock then your atoms are also moving slowly and things appear normal.
Very interesting...
Perhaps you could compare the situation with the speed of sound, for example. If you're traveling at sonic speed, you will not hear sound waves traveling "behind" you as they are trying to "catch up" with you. They have to "wash over" you in order for you to be able to hear them, so-to-speak.
Perhaps due to the consequences of luminal speed in vacuo, it is impossible to feel the effects of time because you're traveling "as fast as" or "faster" than time itself.
No. You still feel the effects of time because you are in an inertial frame relative to yourself. However, the people around you will to you, experience no time, while to the people around you, you will also seem to be experiencing no time.
Time is both a relative and quantized phenomena from a human point of view. I'm not a physicist, so if anyone sees any mistakes with my arguments feel free to point them out.
For a photon traveling at the speed of light the trip from even the most distant galaxy happens instantaneously. As far as the photon is concerned, no time has passed whatsoever and it has magically been teleported across the universe and into the future. From our point of view, the photon has been traveling for billions of years.
The same can be said for a photon falling into a black hole. For the sake of argument, let's assume this black hole forms a wormhole connected to the other side of the universe. From the photon's point of view, it then emerges instantaneously on the other side of the universe in the distant future. From our vantage point of watching the photon fall into the black hole, it never enters the black hole, but steadily slows down and becomes virtually frozen in both space and time.
Again, whether we perceive time as relative or quantized, just depends upon our point of view. Having mass, we cannot accelerate to the speed of light without first shedding our mass. If we could ask Scotty from the star ship enterprise to beam us up, to convert us to pure energy and transport us, again time would appear quantized. If we could then take off on impulse power and accelerate the ship towards the speed of light, time would appear relative.
Thus, exactly what time is or isn't, is impossible to say. After all the observations and analyses are done, all we can say is it is apparently just a question of your personal point of view, but time, space, and existence cannot be distinguished one from another. Time without space, and spacetime without events between "things" that exist is evidently impossible. Or, at least, paradoxical or ineffable.
Forgive me if I am wrong, but, as stated above, what if time is mearly a point of view? We have no clear way to prove the existence of it, and the only evidance we have is it's effects. Couldn't time be rather, a measurement made up by man to explain why things move? A measurement of an object moving from point A to point B over a period of x? Now, I must agree with the definition provided by Aeonic333 at the beginning of this thread. Time is only a measurement used to define more accurately where something happened.
It is thought that powers the world
You could say the same thing about size or shape or existence itself! Maybe we really don't exist! To me such thoughts are a moot point. We have this word we call "time" with an assortment of definitions and whatnot, but it's apparently a useful concept and that does seem to matter to me. If you can prove everything is just thought, it still won't make any difference in my life unless you can also prove it's apparently useful. For all I know time is in reality a fuzzy bunny!
My little explanation of time might be too tame for some who want to time travel or think of it as a spatial dimension.
I believe time can be reasoned out from the way the universe has worked and continues to work. Time is said to have begun with the big bang -- that is why the universe is believed to be upwards of 13 billion years old -- and the big bang, for now, is considered the source of physical existence. Since the big bang, the universe has expanded, radiated away its light, and surrendered its energy.
So what is time? The atomic organization of the universe is essentially what makes it endure, and so its dis-organization, or entropy, is what is ending it. Well, one might ask, how many entropic events are left in the universe before its organization is gone (i.e., when all its light and energy have escaped organizational structure)? That’s important because if there is no more structure, then the universe will be done for, and so “time” will come to an end (I am predicting the end strictly based on how the universe has worked and is working now).
Then there is a second factor and that is, what is the rate of occurrence of those entropic events? Well, that depends on where you are and what is going on. Since time is determined by cycles, and the ultimate cycle for the universe is atomic and light oscillation rates, anything which affects those rates also affects time. If one travels, for instance, the cycles are lengthened and so time slows relative to a non-moving frame of reference. If one accelerates, it has a constrictive effect on the cycles and so also slows time relative to a non-accelerating frame of reference.
Time therefore is the rate of entropy. There is that time, or rate of entropy, for any relative situation; and there is that time, or rate of entropy, for the universe as a whole. How much time is left for the universe is how many entropic events there are before all organization has disappeared. As far as time travel goes . . . with this interpretation of time, time travel is nonsense, as is the notion of it being an actual dimension (beyond a measurement tool).
It seems to me that time could be the result of distortions in the dimensional plane. Of course, I'm just an amateur at this.
Here is some interesting excerpts I saw on the inet when just browsing around. It touchs on this topic of time and light. All bolding emphasis is mine. The first is a statement that agrees with what Wuli was saying. The second is the conclusion of what time is.
"For a long time it was assumed that space and time were fundamental to the underlying reality. Einstein's Theory of Special Relativity came as a great shock to this assumption. He showed that what we observe as space and what we observe as time are but two aspects of a more fundamental spacetime continuum. What this continuum is like we never know -- in this respect it sounds very much like Kant's noumena. All we ever know of it are the ways in which it manifests as the two very different qualities of space and time. Moreover, how much of the continuum manifests as space and how much manifests as time varies according to the relative motion of the observer.
Space and time have fallen from their absolute status. They are both created through the act of perception, and so belong to the relative world of experience. This is not to imply that they are not fundamental to our experience; they are the dimensional framework within which we structure our mental image of the world. But we deceive ourselves when we assume that they are also fundamental to the underlying reality."
...snip snip...
"According to Einstein's equations, as an observer's speed increases, time slows down, and space (in the direction of motion) contracts. At the speed of light, time has slowed to a standstill and space contracted to a point. Although no object with mass can ever attain the speed of light (Einstein's equations predict that it would then have an infinite mass), light itself does (by definition) travel at the speed of light. From light's point of view it has traveled no distance, and has taken no time to do so.
This reflects a unique property of light. In the spacetime continuum there is no separation between the emission of a light ray and its absorption. What Einstein called the "spacetime interval" bewtween the two ends of a light ray is always zero.
How should we understand this? The answer is that we probably should not even try to understand it. Any attempt to do so would once again fall into the mistake of applying concepts derived from our image of reality to the underlying reality. All we need to recognize is that from light's perspective it traverses no spacetime interval.
However, when we perceive the world from our human frame of reference we do indeed observe a separation between the two ends of the light beam -- the exact amount of separation depending upon our speed. We could say the act of perception "stretches out" the zero interval, and divides it into a certain amount of space and a certain amount of time. Since the total interval remains zero, the amount of space created exactly balances the amount of time created. For every 186,000 miles of space, we create 1 second of time.
What we conceive of as the speed of light is actually something completely different. From light's point of view -- and this after all must be the most appropriate perspective from which to consider the nature of light, not our matter-bound mode of experience -- light travels no distance in no time, and therefore has no need of speed. What we take to be the speed of light is actually the ratio in which space and time are created in our image of reality. It is this ratio that is fixed -- and this is why in the phenomenal world the apparent "speed" of light is fixed."
I had a thought earlier today that if the 4th dimension is supposedly time, and gravity is the same as a constant acceleration in the 4th dimension, then perhaps time is the constant acceleration that is gravity
Cytokinesis, Change and motion have no meaning without the concept of time. To speak of acceleration outside of the context of time is an oxymoron, a paradox.
TIME IS A MEASUREMENT!
Thanks Captain Obvious!
Measurement usually implies a dimension of one form or another, and it's a well known fact that time is a dimension, or measurement.
No . . . I think he meant time is ONLY a measurement . . . it has no actual reality beyond that. Calling time a "dimension" was simply to indicate the three spatial dimensions are invariably linked to change, and that change is, overall, the universe's steady march (as of now) toward total entropy.
spacetime is generally accepted as existing in 4 dimensions, right? Our space consists of the first three, leaving time to be considered as the 4th.
Yeah, yeah, and size of the shoes I wear is just an illusion. Without proof one way or the other it is a moot point. I'm still going to use clocks and size my shoes. Taking a biased position on the issue is counterproductive and a waste of time.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 95 ·
  • · Replies 125 ·
  • · Replies 65 ·
13K
  • · Replies 58 ·
