What are the Work and Energy Relationships in a Spring System?
The discussion revolves around the work and energy relationships in a spring system involving a block released from a height above a vertical spring. The problem includes calculating work done by the block on the spring, work done by the spring on the block, and determining the initial height from which the block is released.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of work-energy principles and the conservation of energy in the context of the spring system. There are attempts to relate the work done by the block and the spring to potential energy, with some participants questioning the correctness of their equations and assumptions.
Some participants have provided insights into the relationships between work and potential energy, while others express confusion regarding their calculations and the implications of their results. There is an ongoing exploration of the problem without a clear consensus on the correct approach or final answers.
Participants mention difficulties with the calculations leading to impractical results, and there is an acknowledgment of the constraints imposed by homework deadlines and upcoming exams. Some participants are seeking to understand the underlying concepts rather than just completing the homework.
blakester
A 700 g block is released from rest at height h0 above a vertical spring with spring constant k = 380 N/m and negligible mass. The block sticks to the spring and momentarily stops after compressing the spring 24.0 cm.
(a) How much work is done by the block on the spring?
(b) How much work is done by the spring on the block?
(c) What is the value of h0?
(d) If the block were released from height 2.00h0 above the spring, what would be the maximum compression of the spring?
(KEi + PEi) + W = (KEf + PEf)
W = F*d cos (thet)
F=kx
I plugged in .24m*380N/m (x * k) for the force the spring exerts, but I'm not quite sure what to do from here to get the work for part a. any help is greatly appreciated, even just getting me started.
The Work done/Energy associated with a spring is [tex]\frac{1}{2}kx^{2}[/tex] and I'm guessing all energy is conserved to Wblock = -Work spring
Set Equal to potential energy to get h0
Maximum compression is when Vblock = 0
i see, i guess i had my equation wrong. Well that gets me A and B but I'm having trouble figuring out how to get the second part. if H is 0 where you drop the block, would that make me use -mgh and set that equal to final potential energy (which i don't think i know)?
if i set the answer given from problems a and b equal to potential energy (mgh) i get some ridiculously small number. 10.994 / 700 / 9.8 = h = .00159 which seems impractical and is incorrect
if i have Kei + Ui + W = kf + Uf where Kei, Ui, and kf all = 0 I'm left with W = Uf which gives me the same answer as above where 10.994 = mgh and a lot of division occurs!
I got h0 = 6.51m, I don't know where you got your answer.
hmm h = 6.51 is incorrect according to the website (also tried -6.51).
i've been reading up on this physics site just trying to understand these problems. I've kind of given up on finishing my hmwk by midnight, but i do have a midterm tomorrow and I want to understand how this works so i still want to do the problems heh.
oh and thanks for tryin to help so far i do appreciate the input
  • · Replies 58 ·
  • · Replies 17 ·
