What causes rotation, a couple or a moment? (conceptual)
The discussion centers around the concepts of moments and couples in the context of rotational motion, particularly how these concepts apply to real-world scenarios involving forces acting on extended bodies like rods. Participants explore the physical significance of moments, the conditions under which rotation occurs, and the implications of applying forces at various points on an object.
  • Some participants question whether moments have real physical significance or if they are merely a conceptual tool for understanding couples and rotational effects.
  • There is a discussion about the effects of applying a force at one end of a rod in space, with some stating that it would cause both linear and rotational acceleration.
  • One participant notes that a force does not need to be applied directly on the center of mass (COM) to produce pure translation, as long as it is collinear with the COM.
  • Another participant suggests that different perspectives on the cause of rotation (force vs. couple) can yield the same results, indicating that both views are valid in certain contexts.
  • There is a query about the mechanics of a pivot point when a force is applied, with a participant expressing confusion about how forces influence the pivot while a couple is generated.
Participants express varying viewpoints on the significance of moments versus couples, and there is no consensus on the best way to conceptualize the effects of forces on rotational motion. The discussion remains unresolved regarding the actual mechanics at play when forces are applied to pivot points.
Participants acknowledge the complexity of visualizing the motion of the center of mass when forces are not directed towards it, and there are unresolved questions about the influence of forces at pivot points and the generation of couples.
Sarin
Does a moment have any real (physical) significance or is it just a definition/ an aid to understand and calculate a couple. Is it that the rotation is actually caused by a couple!
I know we can resolve a force causing a moment about a point into a couple and an equal force acting at that point, but what i want to know is how does this actually happen in a real world scenario.
Also,
Say if there was a body (an extended bar or rod) in space so that no force would act on its centre of mass, then if a force F was applied on one of its ends what would happen and why?
forgive me if the question sounds stupid, but this concept has ben bugging me for a very long time now!
The object would undergo a linear acceleration per [itex]m\vec a=\vec F[/itex] and would undergo a rotational acceleration per [itex]\mathbf I \,\dot{\vec\omega} = \vec r \times \vec F - \vec{\omega}\times (\mathbf I \,\vec{\omega})[/itex] .
In words, it's because you apply a force "on" the COM ie. linear acceleration, but a the same time, you apply a torque about the COM ie. rotational acceleration (unless the force is applied directly on the COM, then it's just linear).
A force doesn't need to be applied directly on the CoM (center of mass) to get pure translation. It just needs to be directed "in line" with the CoM. For example, in the case of a force applied at the end of a rod, there is no torque on the rod if the force is directed toward or away from the center of the rod (i.e., if the force is collinear with the rod).
These different views are equally real and produce the same answer. In many cases you can observe the cause of a force producing a moment, so it's natural to view that force as the reality. But in other cases exactly the same result could be produced by a combination of a torque and a linear force.
DH, DJ british ? and Haruspex, thanks!
lol, and DH i think DJ british meant to say the same thing when he said "directly on the COM", please dun give him a hard time, haha.
OK i had been pondering over thisthe whole day, looked up some literature and i think i figured it out, one can even deduce this from the derivation of the "position of COM of a system".
Its just that it is very hard to imagine/ visualize the COM taking a translatory path (motion) when the force is not even acting on it/ directed towards it, i.e offset.
Anyways, I have another problem: a free body, say a bar (yet again), spins about the COM; but if we pivot a body at a point, then why does a force act on the pivot point simultaneously as a couple is generated.
I know one may argue since the forces are equal and opposite on the pivot point, they are as good as non existent (they cancel out each other), therefore it is the same thing. I know that!
I wan't to know how it happens in actuality, i.e if you pin a rod at one of it points, how is that point going to be under the influence of a force.
i know again a stupid question, my apologies.
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 69 ·
  • · Replies 35 ·
