What causes wavefunction collapse?
33 replies · 13K views
SeventhSigma
I've always been confused about something -- I'd love for someone to clear up my ignorance.
I understand that the position of a particle can be modeled as a wavefunction (a probability distribution, to my understanding) where we can describe the position as fundamentally random, but it takes on a value at a frequency in accordance to the distribution once it interacts with something.
My question: What does it mean for it to "interact?"
When two particles collide into each other to take on their "real" states, how does it know when this occurs? In my mind I am viewing it as two clouds of probability heading towards each other. Technically, the clouds are always intersecting because the wavefunction distributes itself across all space and time, right?
Even if I am wrong on that point, my question is what is actually happening here when probability clouds collide. What is the mechanism that describes the actual collapse of the wavefunction from probability clouds to real states? Do they just have to take on the same values at the same time, where this becomes more and more likely as the clouds intersect more intimately?
Sorry if I am not making much sense.
I think the simple answer is that no one TRULY knows.
Roger Penrose has some interesting ideas on wave function collapse. Basically, he feels it is ultimately related to gravity and an explanation for WF collapse will have to be included in any theory that succesfully combines QM with GR.
A google will probably provide more info.
So not only is the real state of the collapse random, but the actual act of the collapse of the wavefunction itself is random?
Granted I am very new to this stuff, and probably don't have nearly the amount of knowledge on the subject as some here, I'll try and help. What you're asking is basically an answer to something called the quantum measurement problem. There are a lot of differing ideas on it, of course, but nothing concrete that is agreed upon by 99% of the scientific community. Basically, when a scientist "looks at" (measures) a particle, it changes from its wavefunction form of limbo into the particles we know and love today -- physical things with exact locations, velocities, spins, etc.
I would start by not calling these things probability clouds. I'd stick with two probability waves (since they are waves, after all -- there are just a lot of them, everywhere). From my reading, wavefunctions interact all of the time -- it's how they discovered wavefunctions exist in the first place! When viewed correctly, interacting wavefunctions create interference patterns, and can thus be observed. The wavefunction doesn't, however, immediately collapse because of this interaction between multiple wavefunctions. It collapses (if wavefunctions even collapse at all) because of . . . well, nobody really knows. We don't even know if a wavefunction even collapses! There are theories, however.
One approach is to abandon the view that that wavefunctions are objective features of quantum reality; instead, they're just an embodiment of what we know about reality. In other words, we don't know where the particle is yet, so we come up with probabilities. Once we gain the knowledge of where the particle is through measuring it, the wavefunction "collapses" and we gain knowledge.
Another, far cooler idea, is the Many Worlds interpretation. If you've ever watched the last season of LOST, you'll have an idea of what it is. Every probability of a particle being here, there, or over yonder in a wavefunction is realized -- the wavefunction never collapses. It's just realized in different parallel universes.
Another thought is that particles do actually have an exact location and spin, etc., at anyone time, just like Einstein thought they should. The wavefunction is not separate from the particle, but is instead included with the particle. So when you find the particle, that's exactly where it was previously, too. Quantum uncertainty comes into play in this interpretation.
There are others, of course, too, but there's a big one that seems to be gaining traction called decoherence. You might want to look some info on it up, since I won't go into much detail here, since, honestly, I can't -- it's confusing! Basically, if I understand it right, the environment is always interacting with wavefunctions, and nudges a wavefunction in one direction or another, giving the particles their classical appearances -- basically how we interact with our environment on our larger scale of everyday life. For instance, photons are always bouncing and hitting things, "blurring" their wavefunctions, and forcing them to appear here or there. No wavefunction collapse occurs, but wavefunctions "blur."
I hope this helps. I am sure I got some of it wrong, and others can go in depth with it far more than I can.
Not every interaction is a measurement. There is no collapse in your example. After the collision, you just have two new clouds. The cloud collapses to a point only if a position measurement is performed.
Having understood this, your new question will probably be "what interactions are measurements then?". In the mainstream interpretation of QM (Copenhagen), this question is not fully answered. Measurement takes place, when you're using a classical measurement apparatus to interact with your quantum system. For example, if you use a photo plate to detect photons.
This is unsatisfactory, since a fundamental theory should also be applicable to the process of measurement itself. This means it should be possible to describe the measurement apparatus quantum mechanically as well, which is quite difficult.
In principle, it should be possible to explain the collapse by so-called decoherence. In this framework, a measurement devices constitutes a large environment for the system of interest. Interactions with this environments on a very short timescale can then be approximated by an instantaneous collapse of the corresponding wavefunction. However, this view is not compatible with the mainstream interpretation of QM.
In the end, most confusing questions about QM reduce to the question 'which interpretation of QM is the right one?' and there's still no consensus about it's answer in the physicists community.
In my mind, interaction and measurement are pretty much the same thing, since I consider a measurement an act of interaction.
And you're wrong. Measurement and interaction are two different things in Copenhagen Interpretation. Otherwise, superposition would not exist at all. There is always some kind of interaction.
This is why I like MWI. That sort of question doesn't enter. There is no collapse in MWI, and that's that. Of course, there are other questions there.
There's always some kind of interaction due to the fact that wavefunctions extend through all time and space, correct?
Can you give an example if interaction versus measurement? I guess I don't understand because all sorts of processes happen without us measuring them. Things take on real values.
A spin-1/2 particle is placed in magnetic field. That spin will precess due to the interaction with the magnetic field, yet its wave function will not collapse, because you are not measuring the actual spin.
That is my question though -- when we say the spin will precess due to its interaction with the field, how are we saying that the wavefunction hasn't collapsed yet? I may be incorrectly assuming that a wavefunction collapse means you change a particle from a state of uncertainty to a state of real confirmation. So for the field to cause the precession in the first place, it needs to somehow interact with the particle.
Or, are you saying that the field affects only certain properties, and these properties are affected along the particle's entire wave function -- but we don't actually know its position until we measure it directly?
Suppose, the spin is initially in the sate |chi>=a|up>+b|down>, and is placed in a magnetic field along x. To within constants, the state at time t is Exp(iHt)|chi>, and H~=Sx. Or when expanded:
[tex]\chi(t)=\left(\begin{array}{cc}cos(\omega t)&sin(\omega t)\\sin(\omega t)&cos(\omega t)\end{array}\right)\left(\begin{array}{c}a\\b\end{array}\right)[/tex]
So |chi>(t)=(a cos(wt) + b sin(wt))|up> + (b cos(wt) + a sin(wt))|down>
Notice that at any given moment, the spin is still in superposition.
I am not familiar with the terminology, but I am assuming that a and b are properties of spin, and the omega-t stuff is the interaction of the magnetic field. The end result is a combination of the two. This corresponds, though, to what I was calling "properties being affected along the particle's entire wave function" (is this inaccurate to say?). Would it be accurate to say that the particle is in many places at once and the field is affecting ALL of those "possible particles"?
What, then, would it look like if we measured it? How would this act of measuring be any different from a field interaction?
This is a point-particle. Its total wave function is given by [itex]\chi(t)\phi(x,t)[/itex]. Phi is what gives the spatial distribution. The parameters a and b are just fraction of wave function corresponding to spin up and spin down respectively.
In measurement, the wave function collapses to eigen states of the measurement operator. Suppose, you measure spin along z of the particle in initial state |chi> above. The eigen vectors of Sz are |up> and |down> vectors from above. So after measurement, with probability a² the state will be just |up> and with probability b² it will be just |down>
I think I need a bit more education on the basics, because I am having a hard time understanding those kinds of explanations when I am not familiar with the terminology.
You say "measure spin along z of the particle in some initial state" -- what does it mean to physically measure a "spin"? How is a "measurement" in itself not an interaction with a physical entity?
You are going to find yourself in the land of semantics pretty quickly here. Spin measurements are usually performed without scattering or absorption. You have also field effects to consider, and those of course should be considered physical. But there are no particles touching other particles in the normal sense of the words.
An 'interaction' between two particles can be modeled for example by writing out schroedinger equation for a system of two particles and adding an extra term V(r1,r2) to the hamiltonian, which represents potential energy of particle interaction. Before the interaction, the WF for a system is a product of WFs of individual particles. After the interaction, in general, the WF of a system is no longer separable, the particles are said to be entangled. The same applies when more complex systems interact with each other. As long as you keep track of the details, there is no collapse.
Interaction causing WF collapse are called 'observation' or 'measurement'. They involve quantum system interacting with macroscopic 'observer' (aka 'detector' or 'measurement apparatus'). Macroscopic is understood as having very large (many orders of magnitude) number of degrees of freedom. Clearly we would have a bit of a problem writing out schroedinger equation for it, never mind solving it, so whatever is going on there is shrouded in mystery. Nevertheless, we find that after such interaction the WF of the particle collapses into an eigenstate of a certain projection operator called 'observable', which is specific to the observer. At the same time the macroscopic state of the observer changes according to the eigenvalue associated with the new state of particle's WF. The interesting part here is while schroedinger evolution is linear, the collapse isn't. So at some point somehow the superposition is destroyed and only one eigenstate is chosen seemingly at random with probability proportional to the square of magnitude. Exactly how, when and why this happens is subject to interpretation.
This is an incredibley helpful post for me in my early research into the problem, thanks!
It is becoming quite a struggle to categorise the different interpretations, would you mind telling me if the bolded section is referring to Bohr's epistemological interpretation? As compared to the Copenhagen interpretation (of which Bohr was instrumental) which appears to be a different concept.
Also, what is the underlined idea(s) referred to as? Thanks!
I don't think that the implication of interaction from measurement [itex](M\implies I)[/itex] is under question (although maybe some here do), but rather the other direction, that interaction implies measurement, [itex](I\implies M)[/itex], these are two different things, you need both for equality.
I seem to agree with K^2 here, but I have some question about the interactions.
How would a silver atoms electromagnetic interaction not cause collapse, but the interaction of the silver atom with the florescent screen would cause collapse? Especially since, at the fundamental level, the interaction with the florescent screen is really an interaction with the atoms in the screen, which is really an electromagnetic interaction also!
But, it's also true that the E&M interaction is not solely responsible for the interaction of the silver atom and the screen, the anti-symmetric nature of the wave-functions also plays a role. If this is your rebuttal then I'm even more fascinated, and have to think more on it... :smile:
That would definitely help. There are a lot of things you can't learn efficiently by just asking questions. Sometimes you need to sit down and listen to a good lecture or read a book.
Measurements are a type of interaction, always. But there are interactions that collapse the state and interactions that do not. In Copenhagen Interpretation, it's not always clear which is which, and that's why more and more physicist switch over to Many Worlds Interpretation. It is more clear on what does and what does not constitute a measurement. You can try reading Wikipedia article on MWI and see if it helps you answer a few of the questions.
Keep in mind that Copenhagen and MWI are equivalent in terms of their prediction. One of these is not better than the other, and you really should understand both to have the better understanding of QM overall.
Because when you get right down to it, collapse doesn't happen when film gets exposed. Collapse happens when you use film for measurement. Again, what constitutes measurement is iffy in Copenhagen. MWI tells you exactly when the apparent collapse should happen.
The Quantum Eraser experiment demonstrates this pretty well. There, the measurement is made, and is then discarded, which prevents the collapse that would have happened due to the measurement. Again, makes little sense in Copenhagen, but perfect sense in MWI.
I'm as biased as anyone else but they way I see it, those interactions that don't collapse the state, are those that either are already implicit in the expected evolution (ie. hamiltonian, interaction terms etc), or that doesn't even couple at all to the system.
This is why the unitary evolution of the schrödinger equation is best thought of as an "expected evolution". When the information on which the prior expectations are based are suddenly changed so does the new expectations.
The whole point with updating to NEW information, is that it isn't previously expected. If it was, it would not be new.
In this picture, there is no problem of the collapse at all. The information update is a basic mechanism of how rational inference works. To think you can do away with an information update is irrational if you have this view. It's instead the key to learning.
Instead the problem is another one: to explain the de facto objectivity we all agree upon when it seems at deepest level all we have are observer dependent expectations.
But in that conceptual picture the idea is that interaction between observers, causes an evolution to take place in a way that not all observers (views) are equally preferred at equilibrium (although they are all possible). So at equilibirum we recover de factor objectivity, simply because those that don't comply are destabilised.
Compare with biology. You can easily picture countless perfectly "consistent" life forms, that we nevertheless don't see in nature? Why? They just don't have a place in the current state of the ecosystem and evolution.
So any two systems that are interacting and communicating, tend to negotiate and reach agreements, and if they don't, they will destroy each other. Similar mechanism could explain objectivity of laws of physics, in such a weird apparently solipsist picture I outlined. It's really like Van der Waals / Casimir like effect that takes place in "theory space".
/Fredrik
That's a Voodoo approach to quantum mechanics. It works when you can clearly define a sub-system. Then yes, whatever is described by the Hamiltonian of the subsystem is not going to collapse the wave function. But external interactions are still not guaranteed to, even though they are "unexpected" from perspective of the sub-system's Hamiltonian. Somehow the system then "knows" whether the interaction is a measurement or not. And that's not good.
Further problem is that this still doesn't explain everything in the big picture. You can't always define a sub-system. That's true in physics in general, but in QM it's particularly severe. Take a look at Quantum Eraser experiment. It's the same interaction, but whether or not it collapses wavefunciton is determined afterwards.
As I see it the "expectations" are always conditional on the observer (observing system), not the subsystem.
I think you mean that if we consider the sub-system as "observing" it's enviroment, but then yes of course the system will konw when it's performing a measurement. This doesn't however mean that a remote observer does. Their views are not an actual contradiction until compared - and the comparasion is a physical interaction.
Paradoxes are most often arrived at by freely comparing views of different observers, without explicitly looking at how the communicating their views would actually be like. The contradiction then translates into an interaction term.
I agree the sub-system decomposition is ambigous, but I was sloppy sorry.
The way I see it there is only one natural partition: What the observer thinks he knows about it's unknown environment, and the enviroment. There is nothing external beyond this.
This means if I am to refine my stance above, my picture is that the obsever always interacts with it's entire environment. And in that picture there simply is nothing "external".
And the EXPECTED evolution of the environment is always unitary by construction. But in general expectations are not always met. But this should produce a backreaction from the environment that forces the observing system to promptly revise it's state or face destabilisation.
Of course, if this is to be consistent, given ANY observer: this observer must be able to arbitrarilty decompose a small(*) subsystem into two parts; observing each other and then infer from that their interactions from some rational action principle. This would be the reality check for this "voodoo picture". The action of the composite system must certainly be invariant with respect to the decomposition!
The insight from this interpretation would provide is that it should be able to possibly do away with referencing classical hamiltonians or lagrangian. The entire action of the system should be constructible from a a pure rational action principle when you consider any arbitrary decomposition as two interacting inference systems.
So, no multiple worlds, just multiple observers, each encoding information about the remainder of the universe, and acting accordingly.
To wrap this up though, some further things is needed to make sense of it, and it's part of my personal views. For example the rational action conjecture which loosely speaking means that ALL actions are ultimately entropic in nature, but there is no objective entropy measure, only observer dependent. This leads to selection dynamics in the observer population, and ultimately equilibrium points where only certain systems (observers) are selected as consistently coexisting. No classical hamiltonian analoges are needed in this abstraction.
/Fredrik
This sounds like Carlo Rovelli's ''Relational Quantum Mechanics".
The part you quote certainly does. The initial part of Rovelli's RQM paper (http://arxiv.org/abs/quant-ph/9609002) is excellent IMHO. I do however strongly diverge from how Rovelli's proceeds. So in the end, this is not at all Rovelli's RQM. What I propose is in the same initial spirit, but far more radical, deprived of far more realism.
The relational thinking in interaction = communication is the same, but my ambition is in fact to reformulate QM and use the idea of rational action as the key to unification. Rovelli clearly states that he does not want to modiy QM, he just tries to reinterpret it into.
I commented on Rovelli's RQM in some othe threads before
https://www.physicsforums.com/showthread.php?t=314441
https://www.physicsforums.com/showthread.php?t=220841
/Fredrik
It's my understanding that this assumes realism holds, which Bell's theorem tells us it might not.
We haven't adequately shown, to my understanding, that the predictive qualities of QM exist outside of measurement.
Not sure what you mean my predictive qualities without measurement. Assuming you aren't speaking of realism, then I agree in this sense:
What we do not yet have, is to show that the ACTION of any composite system, can be EXPLAINED from inferencial first principles in terms of thinking of the interactions as the parts performing measurements on each other, and responding accordingly. This is the idea behind the rational action I mentioned. But this is a conjecture and/or interpretation, it remains to see in the future if explicit unification of actions can be found in this way.
So far, we just come up with a classical hamiltonian or lagrangian and "quantize it" as per some ad hoc rule. This clearly is deeply unsatisfactory.
If so, it would be an indirect confirmation of "measurements as interactions" without actually performing the measurement would be exactly that: if we can perform measurements after some duration of a composite system, then if our predicttions are right (ie if the action/hamiltonian following from rational action is right) then it means the abstraction of explaing physical interaction terms of "negotating observers performing measuremetns on each other" has predictive value. So when worked out, this idea is potentially falsifiable, thus rendering it more than just a pure interpretation.
But this what I suggest is not a restoration of realism at all. It's rather attacking the realism of ensembles and statistics, which only makes sense for small subsystems, where the statistics is encoded in a classical environment and all classical external observers can agree. But this is a special case. And it does not give hints to unification of interactions.
/Fredrik
Fra, when you divide the universe into observer and observed, yes, it all falls into places. But that sort of division only naturally follows from MWI. In Copenhagen, there is no apparent reason to it.
Predictive powers of QM need not hold outside of measurement. If you can't measure it, it does not matter whether our description of it is consistent with actual dynamics, as long as all observables agree with prediction.
That's kind of the whole point of QM. We assume the dynamics of whatever's actually there is linear. Then we replace whatever's actually there with wave function and pretend it is real, but there is absolutely no reason it should be, and it doesn't matter if it is. As long as superposition principle holds, we're good.
I'm not a MWI fan, but most that talk about MWI talk about non-interacting branches. Ie. truly multiverses.
The picture I tried to paint, is with interacting views! That's the whole point, otherwise it gets empty. So there are many INTERACTING observers, not many non-interacting worlds (whatever that even means, I don't know).
/Fredrik
From perspective of one observer, another is just a quantum system. Consider Shroedinger's Cat. The cat is an observer, yet from perspective of outside observer, it does not collapse the wave function of the radioactive atom. It merely goes into an entangled superposition state with it. From perspective of the cat, the atom's wave function has clearly collapsed.
And before you ask, yes, we have experiments that confirm this behavior. Look at Quantum Eraser.
Yes, agreed. As long as the outside observer performs no measurement, the cat-atom "complex" is expected to evolve in unitarily.
But my point is that there is no conflict in this. We can't compare the views of the cat and the views of the outside observer and think they don't match. The merging of two views, requires them to be communicated to the same observer sort of like we need to parallelltransport vectors from one tangent space to another one before we can even define the concept of angles.
The picture is similar, except that there is no objective "transformation" from observer to observer. (Except for special cases! for example SR observers).
Instead this transformation is a physical process, that takes time and according to my conjecture may help explain interactions, rather than cause problems.
/Fredrik
