What concepts/subjects do I need to understand General Relativity?
The discussion revolves around the prerequisites for understanding General Relativity (GR), particularly focusing on the mathematical and conceptual foundations necessary for a high school student. Participants explore various mathematical topics and physics concepts that may aid in the progressive learning of GR.
  • Homework-related
  • One participant expresses confusion regarding the mathematical complexity of GR compared to Special Relativity and seeks guidance on foundational topics to study.
  • Another participant suggests a solid understanding of linear algebra, tensor calculus, and differential equations as essential for GR.
  • A participant mentions their current knowledge of basic calculus and questions the relevance of Lagrangian and Hamiltonian mechanics to GR.
  • It is proposed that learning classical mechanics and electrodynamics is beneficial before tackling the physics of GR, with specific recommendations for textbooks.
  • Some participants emphasize the importance of mastering Special Relativity in its tensorial formulation to avoid confusion with notation in GR.
  • There is a discussion about the level of classical mechanics and electromagnetism that should be understood, referencing specific textbooks and concepts like curl and divergence.
  • One participant expresses difficulty with Lagrangian mechanics and seeks clarification on its knowledge requirements.
Participants generally agree on the necessity of a strong foundation in classical mechanics and electromagnetism before approaching GR. However, there are varying opinions on the specific mathematical topics and the order in which they should be learned, indicating that multiple competing views remain.
Some participants note that the understanding of Lagrangian mechanics is typically acquired after a year of introductory calculus-based physics and multivariable calculus, suggesting a dependency on prior knowledge and definitions.
velixo
I am a high school student. I looked up Special relativity and grasped it pretty easily, without needing to learn any new math. But when I tried to read about general relativity, I was immediately confused by all the math, equations and notation. My problem is that I have no idea where to begin to progressively learn about general relativity. So I would really appreciate it if you could advise me on what (mathematical) topics to look up on before I continue, and preferably in order (for example learn topic 1, then topic 2, etc). Thanks in advance!
What math do you already know?
You need a solid understanding of linear algebra, tensor calculus and differential equations.
I know things up to basic calculus: stuff like derivates, integrals, rotating integrals, differential equations. Trigonometry, if that counts as calculus (I live in sweden so I don't exactly know what americans consider calculus)
Just a question: do Lagrangian or Hamiltonian mechanics play a part in General Relativity?
Learn classical mechanics and electrodynamics before you start learning the *physics* of GR. I'm only saying this because I started learning GR in junior year of high school but I can tell you now that taking a hiatus midway and solidifying the stuff I just mentioned above before jumping back in senior year paid off greatly.
If you learn classical mechanics, electrodynamics, calc 3 (multivariate), and linear algebra then you can start learning from an undergraduate intro text like Hartle's "Gravity".
An introductory text usually won't go into variational principles for the field equations of GR (e.g. Hilbert action / Palatini action) nor into the Hamiltonian formalism. Nevertheless, you really should learn at least lagrangian mechanics before moving on.
For classical mechanics, I've learned about:
Forces, pressure, Newtons laws, momentum
Energy (kinetic and potential)
Thermodynamics
Electricity and Magnetism
Optics
Waves (sound, spring and light - although light is more about quantum mechanics?)
I tried looking at lagrangian mechanics but I got lost at the introduction :P What are the knowledge requirements of lagrangian mechanics?
When I said classical mechanics and electromagnetism I meant like at the level of Taylor and Griffiths respectively. For example, if I asked you what ##\nabla\times E = -\frac{\partial B}{\partial t}## meant physically, would you be able to answer?
Here in the US, people usually learn lagrangian mechanics in 2nd year mechanics classes so basically, at the bare minimum, after a year of introductory calculus based physics and some multivariable calculus. If lagrangian mechanics is confusing to you at this present moment then I would say put off learning GR before you have your mechanics solidified.
I kinda understand it, I've seen some videos on Khanacademy about divergence and curl (don't remember which one that triangle symbol is referring to ) and partial derivatives, but I haven't seen them used in physics. Would this PDF be about the classical mechanics you are referring to?
http://www.physics.rutgers.edu/ugrad/494/bookr03D.pdf
You also need to master SR in tensorial formulation first, or else it will be a haze of greek subscripts and superscripts.
No that is more advanced than what I was mentioning. Here is the table of contents from Taylor's Classical Mechanics book: http://www.uscibooks.com/tay2con.htm
Thanks a whole lot, this seems very useful! Can't thank you enough :)
