What does adding a base dropwise due to an acidic solution?
  • Thread starter Thread starter mrh124
    Base
The discussion revolves around the effects of adding a base dropwise to an acidic solution during the synthesis of Benzocaine in an organic chemistry lab. Participants explore the implications of this method on the reaction process, product formation, and potential side reactions, focusing on the concepts of equilibrium and reaction conditions.
  • Homework-related
  • One participant suggests that adding the base dropwise allows the solution to equilibrate slowly, potentially preventing the formation of less stable precipitates and unwanted side products.
  • Another participant questions the effects of high pH from excess potassium carbonate on the reaction, implying that it may prevent the formation of the main product, Benzocaine.
  • A different participant notes that excess base could lead to hydrolysis of esters, which may impact the reaction outcome.
  • One participant emphasizes the importance of adding the base slowly to react with excess sulfuric acid and to avoid trapping the ammonium form of the product, which could complicate recrystallization.
  • Another participant expresses concern that dumping the base could overshoot the neutral point, leading to conditions that might hydrolyze the product during workup.
Participants express various concerns and hypotheses regarding the effects of adding a base dropwise versus all at once, indicating that there is no consensus on the specific outcomes or mechanisms involved.
Participants reference the potential for different reaction pathways and product stability based on the pH conditions, but the discussion does not resolve the implications of these factors on the overall synthesis process.
mrh124
In my organic chemistry lab we are synthesizing Benzocaine by utilizing .25g of p-aminobenzoic acid, 2.5 ml ethanol, and add .3 ml H2SO4 together. Once this solution refluxes we add 10% K2CO3 dropwise and a precipitate will form.
Lots of details, but all the matters is that we have an acidic solution and are adding a base dropwise. What does adding it dropwise compared to dumping it in do compared to just dumping it?
none
That was a lot of details, but basically we have an acidic solution and we add a base Dropwise. What does adding the base dropwise do compared to just dumping the entire basic solution into the acidic mixture? I'm thinking it has to do with Le Chatlier's principle. Adding a small amount of base allows the solution to equilibrate slowly, while just dumping a huge amount of base in causes the mixture to crystallize (form precipitates) into less stable bigger chunks with unwanted side products and lead to an inaccurate yield.
Organic chemistry is definitely not my forte, but the most obvious thing I can think of: what could happen in the high pH of excess potassium carbonate?
hmm. I'm probably complicating a ton but excess base would make the solution predominately basic preventing certain products from forming (maybe the main product, which is benzocaine?). We are synthesizing benzocaine which involves turning a p-aminobenzoic acid into ethyl p-aminobenzoate. This involves ethanol attacking carbonyl and being deprotonated by HSO4-. Without the deprotonation (wont happen in basic conditions?) the ethanol can become a leaving group instead.
This is a link to the mechanism: http://www.personal.psu.edu/users/j/m/jmg5214/writing_clip_image002_0002.gif
Look for much simpler thing. What happens to esters in high pH?
I want to say that they'll be hydrolyzed or fall apart?
And that's exactly my line of thinking.
Doesn't have to be right, but it is probably the simplest possible explanation.
solubility of benzocaine is marginal in water... better in ethanol. You add slowly to react excess sulfuric acid and then to free-base the product, slowly. when you just dump things together you risk entrapping the ammonium form with the free base. when you recrystallize, you lose the ammonium compound. And you risk overshooting the neutral point and could produce a basic aqueous solution that could start to hydrolyze the product during workup.
10K
12K
10K
