What does this mean? (equation for viscous flows)
4 replies · 2K views · last reply
vktsn0303
While reading a textbook on viscous flows, I came across the following interpretation of an equation:
Typeset expression: v and y = O(Re^(-1/2)), where v is the velocity component and y the distance, both scaled by the Reynolds number Re.
where, v is the vertical component of the free stream velocity and y is the vertical distance from the surface of a solid and Re is the reynolds number.
Can someone please help me understand what this interpretation means?
Thanks in advance
The funny O means 'is of the order of'
My interpretation would be: if the reynolds number quadruples, v and y become approximately half as big
Often the funny O is used instead of 'is proportional to' (##\propto##) if the reasoning aims to justify ignoring certain terms. But I don't know if that is true in your context.
The order symbol expresses a concept similar to proportionality but not quite the same. It's a statement of how one function grows relative to another. In this case, ##v## and ##y## grow as ##Re^{-1/2}##. In other words, ##v## and ##y## are bounded by ##Re^{-1/2}## multiplied by some factor as they grow. This can imply proportionality but does not necessarily. Essentially, proportionality is a stronger constraint.
The "O" is called "big O notation". It means "on the order of magnitude of" Your average student body size for a college campus might be O(10^4) (between 10,000 and 99,999 students), but your average classroom size might be O(10^1) (10 to 99), for example.
This is called viscous flow.In this when you go upward from a fixed surface the velocity of the layer of liquid increases.At the bottom layer velocity would be zero and at top velocity of layer would be maximum.Reynold number shows that upto a specific value of Reynold number flow would be viscous and beyond that number flow would become transit and the turbulent flow.see the images below.
Slide titled REYNOLDS NUMBER listing flow regimes: Laminar Flow Re < 2000, Unstable Flow 2000 < Re < 4000, Turbulent Flow Re > 4000; below it the formula Re = VD/gamma with definitions of D, V, gamma and Re.
imgaes2
Diagram of a velocity profile in viscous shear flow: horizontal arrows of increasing length rise from the bottom wall, with a curved profile against y and velocity u axes, a tangent line marking the gradient du/dy, and shear stress tau shown as a double-headed arrow near the wall.
  • Slide titled REYNOLDS NUMBER listing flow regimes: Laminar Flow Re < 2000, Unstable Flow 2000 < Re < 4000, Turbulent Flow Re > 4000; below, Re = V D / gamma with variable definitions for D, V, gamma and Re.
