What does this thing on batteries mean?
  • Level: Undergrad
  • Thread starter Thread starter Sam19KY
    Batteries Mean
5 replies · 2K views · last reply
Sam19KY
Say that 6V battery is connected to a lamp that takes 3V from each coulomb. Does that mean that the battery can supply 6V or dependent upon the need of components in the circuit ?
What do you mean? "Take 3V from each coulomb" is totally meaningless.
It will supply 6V to any lamp connected across it since it is a 6V battery. Work done per unit charge is the potential difference, which is 6V here.
Hi Sam. Is there any way you could clarify what you're asking using standard terminology? It sounds like you're referring to a lamp which has a voltage drop of 3 volts. Voltage drop is the loss of energy as current flows through a circuit. A voltage drop of 3 volts means that for every coulomb of charge that passes through the lamp, 3 joules of energy are "lost" to the lamp, leaving a remaining 3 joules/coulomb for the rest of the circuit.
It means that while the battery is supplying 6 volts to the circuit as a whole, only half of that is being used by the lamp. The other 3 volts are being used elsewhere in the circuit.
