goonking said:
Lets say for example, we are given:
dy/dx - 4y = 2 or y' - 4y = 2 , y(0) = 4
=> M= e^(-4t)
e^(-4t) y' - 4e^(-4t)y = 2 e^(-4t)
e^(-4t) y = -1/2 [ e^-4t ] + C
y = -1/2 + Ce^4t
When t = 0, y = 4
4 = -1/2 + C
C = 4.5
therefore... y = -1/2 + 4.5e^4t
Now, is -1/2 the null function or particular? what about for 4.5e^4t?
Several of your posted questions have been about this topic, so I'm hopeful I can shed some light on it.
With regard to your example, there are two differential equations.
Homogeneous: y' - 4y = 0
Nonhomogenous: y' - 4y = 2
A homogeneous equation has an expression involving y and its derivatives on one side of the equation, and 0 on the other side.
A nonhomogenous equation has an expression involving y and its derivatives on one side of the equation, and a nonzero expression involving the independent variable (x or t or whatever, but not the dependent variable, which here is y).
The null solution (or as it's more commonly called, the complementary solution) is the solution to the homogeneous equation. In this case, it is y = Ce
4t. The particular solution is a solution to the nonhomogeneous equation.
The general solution of a nonhomogeneous equation consists of the complementary solution plus the particular solution.
goonking said:
I was imagine a long period of time before the "system" starts, so t = negative infinity, then the exponential function would approach 0, and we would be left with y = -1/2
if t = 0, when the system just starts, we were given y = 4
now after a very long period of time, t = infinity, y = infinityWhat does this mean? the system has no steady state?
Correct, the system has no steady state. Assuming that ##t \ge 0##, y(t) is steadily increasing. That's because of the increasing exponential function in the complementary solution.
