What Happens to Water Pressure in a Glass When Inverted?
  • Context: High School
  • Thread starter Thread starter adameverett
    Water
The discussion revolves around the behavior of water pressure in a glass when inverted, particularly focusing on the pressure readings of a hypothetical submarine descending within the glass and the implications of atmospheric pressure. It also touches on related queries about water pressure in sealed tubes and underground pipes.
  • One participant describes the pressure at the surface of the water as equal to atmospheric pressure and explains how pressure increases with depth according to the formula hdg.
  • Another participant suggests that inverting the glass creates a partial vacuum, allowing water to remain in the glass, and notes that the submarine would experience lower pressure at the surface of the glass compared to the tank level.
  • A different participant raises a related question about a sealed tube filled with water, inquiring about the necessary height-to-diameter ratio to maintain water in the tube when inverted.
  • Responses to the tube question emphasize the importance of ensuring the tube is completely filled and submerged to maintain the water column, while also noting that atmospheric pressure can support significant heights of water.
  • Another participant discusses a practical scenario involving a long underground pipe and seeks a formula to determine the water pressure at the lower end, providing specific measurements and expressing concern about pressure ratings.
  • One participant offers a formula for calculating pressure based on height difference, while another confirms the height difference between the two ends of the pipe.
Participants express various viewpoints regarding the behavior of water pressure in different scenarios, with some agreement on the principles of pressure change with depth. However, there is no consensus on the specific conditions required to maintain water in inverted tubes or the implications of pressure in the underground pipe scenario.
Some discussions involve assumptions about atmospheric pressure and the behavior of water in different configurations, which may not be universally applicable without further clarification or conditions specified.
This discussion may be of interest to individuals exploring fluid dynamics, particularly in practical applications involving water pressure in various contexts, such as inverted containers and underground piping systems.
adameverett
Water Preasure Please answer...
hi,
I'm from the uk, I am a complete novice (no physics PHDs) Please don't Flame me..., I just registered on the site to get an answer to a question that my mates are arguing about. I'm sorry if its trivial or posted in the wrong forum.
My question is,
If I filled a glass of water and inverted it and held it above the surface of the tank of water, the water stays in the glass. Now, if you were to imagine a miniature submarine that started at the top of the glass and descended down what would the pressure gauge read as it traveled down the glass?
And then the pressure at the bottom of the glass level with the surface water of the tank?
I would then expect the reading to increase in pressure as it descends into the tank as normal.
If anyone can settle this argument much appreciated...
thanks
adam a physics newbie.
At the surface the pressure is equal to atmospheric pressure(H).As you descend into the water the pressure increase is given by...hdg(h=depth d=water density g=acceleration due to gravity).This gives a total pressure of H+hdg.If you ascend into the glass the pressure decreases by hdg(here h stands for the height above the surface)and the total pressure is H-hdg.
Adam - You've made a barometer. When you invert the glass of water and expose it to the tank, some of the water will escape into the tank - enough to allow a partial vacuum to form at the 'bottom' of the inverted glass. The air pressure between the glass and water will be lower than the ambient air pressure (recall how a mercury or alcohol barometer works) - just enough to 'hold' the remaining water in the glass above the tank level. The pressure gradient from the surface of the glass water to the bottom of the tank is continuous as indicated in Dadface's post.
The submarine will see a pressure lower than ambient air at the surface in the glass and then as it decends see the pressure increase at ~0.5 psi/ft (it will see ambient pressure at the tank water level as Dadface pointed out).
I too am a novice on this site and am trying to find an answer to a similar question which is: I filled a tube 48" x 1.5" with water, sealing one end and then inverted it - I expected the water to remain due to the vacuum but it did not. Is there a certain ratio of ht. to dia. required to keep the water in the tube? I would appreciate any imput, guidance or direction on this...Thank you!
Try again but make sure the tube is completely filled with water.Hold your hand or something suitable over the open end and don't remove it until it is completely immersed under water.Atmospheric pressure is capable of supporting a column of water about 10 meters high so it should support a column of the length you have.The height to diameter ratio does not matter unless the tube has a tiny diameter in which case surface tension effects become more appreciable.
ralph - if you are simply "turning your pipe upside down" chances are the water will just pour out (especially with a pipe as big as 1.5 inch diameter). The key is to keep the open end of the pipe underwater. If you could hold the filled pipe underwater (say while standing in a swimming pool), and then raise it up to a vertical position from below the water, you'd probably have better luck. Also, you need to be sure the closed end is well closed - if air can leak in there it will ruin the effect by allowing the pipe to drain.
Well this seems to be a good site for me as I too am a novice from Canada with a problem. I need a "simple" formula to determine water pressure.
I have installed a 2 inch high density polyetholine pipe underground for a distance of 2km. The grade on the pipe is between 0.7% and 0.9%. I have estimated I will require about 6.6 ton of water to fill the pipe. How do I determine how much water pressure will be at the lower end of the pipe? The OD of the pipe is 2 inches while the ID is 1.75 inches.
I have installed valves at both ends of the pipe so I feel confident that I can control the flow of water, but I am worried that when I open the upper valve the pressure will exceed the pressure rating for the fittings at the lower end.
It's just p=mgh. Do you know what the actual height difference is between the two ends of the pipe?
Yes. The top end is 37 ft asl and the bottom end is 2 ft asl. The exact distance between the two points is 5,284 ft.
Well, p=mgh. Since the weight density of water is 62.4 lb/cu ft, p=62.4*35= 2184 lb/sq ft or 15.2psi.
Often, though, in English units we just use the height as a unit of pressure: that's 35 ft of static head pressure.
  • · Replies 39 ·
16K
  • · Replies 20 ·
