What is a isotropic harmonic potential?
Ed Quanta
Well, what is it? If two particles are interacting in an isotropic harmonic potential, then how does this differ from an ordinary harmonic potential?
Isothrope harmonic potential means that INSTEAD OF
V(x,y,z)=k_{1}\frac{x^{2}}{2}+k_{2}\frac{y^{2}}{2}+k_{3}\frac{z^{2}}{2}
YOU HAVE
V(x,y,z)=\frac{k}{2}\left(x^{2}+y^{2}+z^{2}\right)
You can see that this case is spherically symmetric...
Daniel.
A isotropic harmonic potential is a type of potential energy function that describes the interaction between particles in a system. It is called "isotropic" because it is independent of direction, meaning that the potential energy does not change based on the orientation of the particles.
In an isotropic harmonic potential, the potential energy between two particles is directly proportional to the square of the distance between them. This is similar to an ordinary harmonic potential, where the potential energy is also proportional to the square of the distance. However, the key difference is that in an ordinary harmonic potential, the potential energy varies with direction, while in an isotropic harmonic potential, it remains the same regardless of direction.
This means that in an isotropic harmonic potential, the particles experience the same amount of force in all directions, whereas in an ordinary harmonic potential, the force may vary depending on the direction of the particles. This can result in different behaviors and dynamics of the system, as the particles may move differently in response to the force.
Overall, an isotropic harmonic potential is a specific type of harmonic potential that simplifies the interaction between particles by assuming that the potential energy is the same in all directions. It is commonly used in various fields such as physics, chemistry, and materials science to model the behavior of particles in a system.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
