What Is Acceleration and How Does It Relate to Velocity and Time?
6 replies · 2K views
oldspice1212
Hi guys, I've been having a pretty hard time understanding exactly what acceleration is, the definitions I usually see are always different, so from what I've read, I know acceleration is a vector quantity and the definition is basically change in velocity?
So if let's say a car is going 45 km/h east, and it changes its route to and speed (magnitude) to 35 km/h west, that would be change in acceleration right? Or do you have to account in the time as well, acceleration = velocity / time?
I may be over thinking this concept, but would be nice if someone can really clarify this for me, thanks again, huge fan of the physics forums.
on Phys.org
No. It's change in velocity over a change in time. :wink:
That would be a change in velocity. Not a change in acceleration.
What do you know about calculus? It's easy to explain if you know derivatives.
Ah right change in velocity over time lol. I've taken calculus one, so yes I know about derivatives and such :p.
This is essentially correct. To make it fully correct, say the rate of change in velocity. Rate implies that the "change" is divided by the time over which the "change" happens.
Just like velocity itself is the rate of change in displacement.
Mathematically, these "rate of change" things are known as "derivatives". Velocity is the derivative of displacement, and acceleration is the derivative of velocity (and the second derivative of displacement).
Change in velocity. It is -80 km/h. Note the minus sign, I assume that the eastern direction is positive.
Not exactly. You do not need just time, you need the time it took for the change to occur. In your example, you did not give that time. If it took the car 20 seconds to undergo that change (say, by going through a roundabout), then the rate of change in velocity is (80 km/h) / (20 s) = 1.1 m/s2.
Alright. That's good. Then, I'll introduce you to a new concept.
Since we can write a vector, let's say ##\vec{x}=\begin{bmatrix}x_1 \\ x_2 \\ x_3\end{bmatrix}##, as a sum of the form ##\vec{x}=x_1\begin{bmatrix}1 \\ 0 \\ 0\end{bmatrix}+x_2\begin{bmatrix}0 \\ 1 \\ 0\end{bmatrix}+x_3\begin{bmatrix}0 \\ 0 \\ 1\end{bmatrix}##, we can say that vectors are differentiated by components. That is, ##\frac{d\vec{x}}{dt}=\frac{d}{dt}\begin{bmatrix}x_1 \\ x_2 \\ x_3\end{bmatrix}=\begin{bmatrix}\frac{dx_1}{dt} \\ \frac{dx_2}{dt} \\ \frac{dx_3}{dt}\end{bmatrix}##. This is the definition of the derivative of a vector (in Euclidean space) with respect to a scalar.
Thus, if we call ##\vec{x}## our displacement vector, then ##\vec{v}=\frac{d\vec{x}}{dt}## is the velocity vector and ##\vec{a}=\frac{d^2\vec{x}}{dt^2}## is the acceleration vector.
@Voko
Thanks Voko, I remember how the concept of derivatives relates to acceleration and other physics quantities now, your definitions were very helpful.
@Mandelbroth
I see somewhat of what you're saying, but at other places I feel lost lol, I'll have to fresh up on my linear algebra I think to fully understand the acceleration vector as you presented it. It is very much appreciated though, thank you!
Thanks guys!
I'll put it in layman's terms.
You're traveling on a cycle.
You're speed after 1 second in 5 seconds is
0 second- 0 m/s
1 second- 2 m/s
2 seconds - 4 m/s
3 seconds - 6 m/s
4 seconds -8 m/s
5 seconds - 10 m/s
So what is happening is, you are increasing your speed by 2 m/s after every second. This makes your acceleration 2m/s/s or 2m/s^s.
This is just linear acceleration. For direction change, vector diagrams aer necessary.
