DaTario
- 1,096
- 46
Hi All,
I would like to know what is dark matter.
Thanks
DaTario
Thanks
DaTario
The cosmological constant has nothing necessarily to do with dark matter. Furthermore, dark energy may or may not be a cosmological constant.Naty1 said:It's a name for the cosmoligical constant from general relativity.
In astronomy and cosmology, dark matter is a conjectured form of matter that is undetectable by its emitted electromagnetic radiation, but whose presence can be inferred from gravitational effects on visible matter and background radiation.
The legend said:Well Chalnoth is right.
Wikipedia is really a great database. Actually the thing is even I didnt know much about dark matter myself. Wiki helped!
Here's the definition from wikipedia:
For more info go to
http://en.wikipedia.org/wiki/Dark_matter
bapowell said:The cosmological constant has nothing necessarily to do with dark matter. Furthermore, dark energy may or may not be a cosmological constant.
I think questions as broad as "What is dark matter" are best researched on one's own outside the forum. When you have a basic understanding, come back and ask more specific questions. Then we'd be happy to help.
Yes.DaTario said:So I am inclined to think that questions as broad as
what is time?
what is space?
what is energy?
what is momentum?
may also be first looked up in wikipedia, am I correct?
This was an early proposed solution, but detailed investigation showed that it didn't work. In particular, dark matter has a very different distribution from the normal matter: normal matter can lose energy by radiating, and so collapses into things like stars and galaxies. By contrast, dark matter loses very little energy with time, and so doesn't tend to collapse nearly as much as normal matter.DaTario said:Ok Thanks for redirecting me to Wikipedia. But now I would like to ask (only to those who is interested in giving answers, of course) if this emission criteria for defining dark matter may be interpreted as celestial bodies far enough and emitting so small an amount of radiation (planets, for instances) that we cannot detect it due to scattering or absortion in the midway.
It seems that there is another possibility, namely: a different patern (species) of matter.
And the simple answer is – No one knows, it's a mystery!DaTario said:I would like to know what is dark matter.
http://hubblesite.org/newscenter/archive/releases/2006/39/image/a"
Hot gas detected by Chandra in X-rays is seen as two pink clumps in the image and contains most of the "normal," or baryonic, matter in the two clusters. The bullet-shaped clump on the right is the hot gas from one cluster, which passed through the hot gas from the other larger cluster during the collision. An optical image from Magellan and the Hubble Space Telescope shows the galaxies in orange and white. The blue areas in this image depict where astronomers find most of the mass in the clusters. The concentration of mass is determined by analyzing the effect of so-called gravitational lensing, where light from the distant objects is distorted by intervening matter. Most of the matter in the clusters (blue) is clearly separate from the normal matter (pink), giving direct evidence that nearly all of the matter in the clusters is dark.
The hot gas in each cluster was slowed by a drag force, similar to air resistance, during the collision. In contrast, the dark matter was not slowed by the impact because it does not interact directly with itself or the gas except through gravity. Therefore, during the collision the dark matter clumps from the two clusters moved ahead of the hot gas, producing the separation of the dark and normal matter seen in the image. If hot gas was the most massive component in the clusters, as proposed by alternative theories of gravity, such an effect would not be seen. Instead, this result shows that dark matter is required.
Comparing the optical image with the blue emission shows that the most of the galaxies in each cluster are located near the two dark matter clumps. This shows that the galaxies in each cluster did not slow down because of the collision, unlike the hot gas.
Thanks Orion1 for a thorough explanation.Orion1 said:The current leading candidate for dark matter is supersymmetry (SUSY) particles, called neutralinos.
Orion1 said:If supersymmetry exists close to the TeV energy scale, it allows for a solution of the hierarchy problem of the Standard Model, i.e., the fact that the Higgs boson mass is subject to quantum corrections which — barring extremely fine-tuned cancellations among independent contributions — would make it so large as to undermine the internal consistency of the theory. In supersymmetric theories, on the other hand, the contributions to the quantum corrections coming from Standard Model particles are naturally canceled by the contributions of the corresponding superpartners.
Oh, no, not at all. SUSY models most definitely include Higgs bosons.DevilsAvocado said:Correct me if I'm wrong, but as I understand you there is some 'incompatibility' between SUSY and the Higgs boson (mass)?
Hi Chalnoth! What's up (with "planck s"Chalnoth said:Oh, no, not at all. SUSY models most definitely include Higgs bosons.
Well, since we don't know what the dark matter particle is, we obviously can't say for sure. However, that said, in quantum field theory, even SUSY, there remains a fundamental problem: if you insert a non-zero fundamental mass for any particle in the theory, it leads to a mathematical contradiction. This means that all masses must arise from interactions. For single particles, that interaction is modeled by an interaction with one or more Higgs fields. For composite particles (like protons and neutrons), it's a complex combination of interactions between the Higgs fields and the binding energy of the component particles.DevilsAvocado said:So what do you say about this:
Does the Higgs boson interact with DM to give it mass?
And if so – Will we then have an indirect 'link' to DM through Higgs?
And if so – Why does DM interact with the Higgs boson, and no other boson?
If not so – What gives DM mass?
I know that the Higgs boson is expected at LHC, but also that prominent scientist like http://vimeo.com/4062801" – "Well, I think it'll be a lot more exciting if we don't find it."Chalnoth said:This means that all masses must arise from interactions. For single particles, that interaction is modeled by an interaction with one or more Higgs fields.
Okay, but isn't it 'weird' that DM does not interact directly with itself (except through gravity)? Electrons and photons (must?) do. Well, maybe neutrinos don't...Chalnoth said:Finally, if you think it strange that DM would interact with the Higgs and not other bosons, consider this:
Well, yes, in part because it would point us in an entirely new, unexpected direction of high-energy physics. Finding new information is always interesting, but finding things that nobody expected are often more interesting.DevilsAvocado said:Thanks Chalnoth, interesting answers as always.
Sadly I worry that the energy available at the LHC may simply be dramatically insufficient to say much about dark energy, or even about much of high-energy physics. As for dark matter, the LHC just won't be good at either producing or detecting such particles, so it's somewhat unlikely that we'll see them.DevilsAvocado said:I have absolutely no clue about the complicated math behind all this. But I do know there are some 'difficulties' in getting all 'pieces in place', like the measured cosmological constant, that is smaller than the calculated quantum field vacuum energy by a factor of 10-120. And we don't know what DM really is. And 90% of the mass in nucleons comes from quantum fluctuations (virtual particles), etc.
If dark matter is a WIMP -- a weakly interacting particle, then it interacts through the weak force as well as gravitationally. Thus, it would couple to W/Z as well as with itself through neutral currents.DevilsAvocado said:Okay, but isn't it 'weird' that DM does not interact directly with itself (except through gravity)? Electrons and photons (must?) do. Well, maybe neutrinos don't...
So far as I know, the "weak" in WIMP doesn't specifically relate to the weak nuclear force. Rather it's just a statement that its interactions with itself and other matter, whatever they may be, are rather weak. We don't yet know what those interactions are: they could be the weak nuclear force, they could be something else. But they aren't electromagnetism or the strong nuclear force (as with those interactions they'd simply interact too strongly with normal matter).bapowell said:If dark matter is a WIMP -- a weakly interacting particle, then it interacts through the weak force as well as gravitationally. Thus, it would couple to W/Z as well as with itself through neutral currents.
bapowell said:Thus, it would couple to W/Z as well as with itself through neutral currents.
Okay, so if LHC find (confirm) the Higgs boson, we can say nucleons get 90% of its mass from Quantum Chromodynamics, and 10% from Higgs.Chalnoth said:The mass of nucleons, on the other hand, is, I believe, a rather well-understood consequence of quantum chromodynamics.
Probably, as electrons, neutrinos, and the W/Z bosons are expected to.DevilsAvocado said:Okay, so if LHC find (confirm) the Higgs boson, we can say nucleons get 90% of its mass from Quantum Chromodynamics, and 10% from Higgs.
Would it then be 'safe' to predict that the 'voluminous' Dark Matter gets 100% of its mass from Higgs?
Okay, thanks Chalnoth.Chalnoth said:... it doesn't interact much with itself.
Interesting! So the reason nucleons get 'fatter' with the help of Quantum Chromodynamics – is because they are much heavier, right?Chalnoth said:Probably, as electrons, neutrinos, and the W/Z bosons are expected to.
Thanks for clarifying, but my point is simply that several WIMP candidates do interact through the weak nuclear force. Up to this point in the thread, this has not been addressed.Chalnoth said:So far as I know, the "weak" in WIMP doesn't specifically relate to the weak nuclear force. Rather it's just a statement that its interactions with itself and other matter, whatever they may be, are rather weak. We don't yet know what those interactions are: they could be the weak nuclear force, they could be something else. But they aren't electromagnetism or the strong nuclear force (as with those interactions they'd simply interact too strongly with normal matter).
Well, it all has to do with how the binding energies work out in QCD. Consider an electron and proton that are far away. The total mass of the electron and proton will just be the sum of the masses of the two. But, if you bring the two together to form a hydrogen atom, this changes: bringing the electron and proton together lowers their electrical potential energy (making the electrical potential energy negative). This means that the Hydrogen atom is actually very slightly less massive than the sum of the masses of an electron and a proton individually. Of course, the magnitude of this potential is actually very small compared to their masses, so it's a pretty negligible effect.DevilsAvocado said:Interesting! So the reason nucleons get 'fatter' with the help of Quantum Chromodynamics – is because they are much heavier, right?
The total aggregate mass of dark matter is many times that of the normal matter. This doesn't mean that the particles themselves need to be particularly massive. Though many dark matter candidates are very massive, axions, for instance, are not.DevilsAvocado said:But, correct me if I’m wrong – Isn't DM one of the heaviest stuff we know in universe??
The quantum vacuum doesn't have a mass, it has an energy. The energy associated with the vacuum is very strange indeed. It has a constant energy density and a negative pressure. Vacuum energy doesn't behave like matter. For one thing, it doesn't clump like dark matter appears to do. Also, it causes the expansion of the universe to accelerate. One possibility for the accelerated expansion that we observe today is called 'dark energy', and might be due to some form of vacuum energy.DaTario said:Is it possible that DM be associated with the mass of quantum vacuum ?
bapowell said:The quantum vacuum doesn't have a mass, it has an energy.
It's more than just energy density, though, but also momentum density, pressure, and shear. Though in the isotropic case only energy density and pressure provide any contribution.DaTario said:General Relativity allows one to infer gravitational effects from energy densities.
Indeed. Did I say anything that was counter to that?DaTario said:General Relativity allows one to infer gravitational effects from energy densities.
This is so cool!Chalnoth said:... But for nucleons, the situation is entirely different. The strong nuclear force, instead of dying away with distance, actually gets stronger. This means that if you hold a quark and anti-quark some distance apart, the strong force between them produces a very large positive potential energy, rather like if they were held together by a spring under tension. In fact, if you pull the quark and anti-quark too far away from one another, the tension between them gets so great, that a quark/anti-quark pair pops out of the vacuum between them and instead of a pair of quarks, you now have a pair of mesons.
Anyway, so if you have three quarks, two ups and a down, sort of the minimum-distance configuration they can have is actually so that these gluon "springs" between them actually have quite a lot of tension. So much, in fact, that protons aren't just made out of three quarks, but three quarks plus a whole bunch of quark/anti-quark pairs continually popping in and out of the vacuum. Of course, energy is conserved when these quark/anti-quark pairs pop in and out, so you can think of the extra energy as coming from the tension of these gluon "springs" between the quarks.
Okay thanks. The obvious conclusion – there can be a lot of DM particles.Chalnoth said:The total aggregate mass of dark matter is many times that of the normal matter. This doesn't mean that the particles themselves need to be particularly massive. Though many dark matter candidates are very massive, axions, for instance, are not.
In order for an object to become a black hole, its stress-energy must be compressed into a region smaller than a sphere of radius equal to the Schwarzschild Radius:DevilsAvocado said:Just one question: What prevent the ups and down quarks from 'imploding' into a micro black hole? (Uncertainty principle?) Or reversed, what creates the strong tension?
Thanks bapowell, the Schwarzschild solution is very interesting, and I’m going to dig into that.bapowell said:... Therefore, the question of whether an elementary particle will collapse into a black hole depends on whether its Compton wavelength is larger or smaller than its Schwarzschild radius.
Not really, no. In QCD, quarks are precisely point-like particles. In a quantum-mechanical sense, of course, this is a bit subtle of a definition to grasp, but ultimately it means that the interactions between quarks and gluons are modeled in QCD as occurring at singular points.DevilsAvocado said:So one could say that the Uncertainty principle + Compton wavelengths give the quarks a "dimension/size", right?
Nope. Now, it turns out that the mathematics that goes into modeling the particles as points in QCD (and in electroweak theory) leads to infinities. We get rid of these infinities by sort of artificially cutting off the sums at some high energy (which is equivalent to assuming that there is some size, even if we don't know what it is). The behavior at high energies is then modeled with a series of parameters that must be measured experimentally. So if the particles are actually extended objects, such as strings (as in string theory strings), then these sums have a natural cutoff at some rather high energy, and the theory is finite.DevilsAvocado said:And this "dimension/size" is what causes the gluon "springs" tension, right?
I don't think that it has anything to do with that at all.DevilsAvocado said:Could one also summarize and say that - the Uncertainty principle is the base for the "Quantum Chromodynamics Mass" in nucleons?
Chalnoth said:... Anyway, so if you have three quarks, two ups and a down, sort of the minimum-distance configuration they can have is actually so that these gluon "springs" between them actually have quite a lot of tension.
Chalnoth said:Not really, no. In QCD, quarks are precisely point-like particles. In a quantum-mechanical sense, of course, this is a bit subtle of a definition to grasp, but ultimately it means that the interactions between quarks and gluons are modeled in QCD as occurring at singular points.
That might be more reasonable.DevilsAvocado said:Could you think of it like – the quarks always want to be free (maybe silly), they always want to "run away", but the strong force wants to hold them together? And this is what causes the gluon "springs" tension...?
(... maybe this works in kindergarten ...?)
There is electrostatic repulsion amongst some of the quarks. That makes them maybe want to run away. At least that's what my 1st grade teacher always said.DevilsAvocado said:Could you think of it like – the quarks always want to be free (maybe silly), they always want to "run away", but the strong force wants to hold them together? And this is what causes the gluon "springs" tension...?
Chalnoth said:That might be more reasonable.
Thanks Chalnoth & bapowell. This gives me some hope on 'basic understanding'.bapowell said:There is electrostatic repulsion amongst some of the quarks. That makes them maybe want to run away. At least that's what my 1st grade teacher always said.
Okay, now I’m confused again... I feel little like that "uncertainty principle" has taken over my whole body...Ich said:But it's the uncertainty principle that makes the quarks want to run away. I don't see why one should say that it has nothing to do with it - or with zero point energy, for that matter.
Yup, the fact that the gluons themselves carry strong-force (color) charge means that they couple not only to quarks, but also to themselves. This is what makes it so that the strong force acts sort of like springs between the quarks, as the charged gluons form a sort of tube between nearby quarks.George Jones said:Unlike photons, gluons can be (colour) charged, and the interaction of virtual gluons plays a role here. See pages 68-70 (largely qualitative) from
http://books.google.com/books?id=w9Dz56myXm8C&printsec=frontcover#v=onepage&q&f=false.
Chalnoth said:Yup, the fact that the gluons themselves carry strong-force (color) charge means that they couple not only to quarks, but also to themselves. This is what makes it so that the strong force acts sort of like springs between the quarks, as the charged gluons form a sort of tube between nearby quarks.
