What is electric field problem?
The discussion revolves around a problem involving electric fields generated by two uniformly charged plates. The original poster presents a scenario with specific charge density, dimensions, and separation distance, prompting questions about calculating the electric field, voltage, and charge on the plates.
  • Participants explore the relationship between charge density and electric field, questioning how to apply given formulas. There are attempts to clarify the units involved and how to derive values from the provided equations.
Participants are actively engaging with the problem, attempting calculations and clarifying misunderstandings about units and relationships between variables. Some guidance has been offered regarding the interpretation of charge density and its implications for the calculations.
There are ongoing discussions about unit conversions, particularly regarding the dimensions of the plates and the separation distance. Participants express confusion over the large numbers resulting from their calculations and question the validity of the charge density provided.
physics(L)10
Two uniform plates have a uniform charge density of 10 Coulombs/m2. The plates have dimensions of 0.6x0.6 m2 and are separated by 2mm
a) The electric field (V/m) between the two plates is given by E=1.13x1011 Q/A where Q is the charge in Coulombs on one plate and A is the area in m2. Evaluate the field.
b) What is the voltage between the two plates?
c) What is the charge on one plate?
E=F/q
V=W/q=EL,
where L=distance,E=electric field, F=force, q=charge, V=voltage, W=work (J)
This is really confusing me. There's so much information, I just don't know which info I can ignore. I think I got all the equations needed for this question though. Help pleaseeee.
Part (a). Evaluate the field means calculate its value. You are given the formula in the problem statement, but you need to plug in Q/A. What are the units of Q/A?
Part (b). Use V = EL. Plug in the value for E that you get from part (a).
Part (c). If you did part (a), you must have figured out what Q/A is. Use this to figure out Q.
a) Well it gives 10 Coulombs/m2 which equals Q/A, so how do I relate this to E=1.13x1011 Q/A?
b) V=(answer in A)(.00002m)
c) I still don't quite understand
Maybe if I rewrite this in symbols you will see:
Q/A = 10 columbs/m2
E = (1.13 x 1011)(Q/A)
What is E?
Ooooooh I see, thanks, you made that really clear. So,
E = (1.13 x 1011)(10) = 1.13x1012 Coulombs/m2
b) V = EL = (1.13x1012)(.0002m) = 2.26x108Volts
c) I'm going to attempt this one and say that since you said E = (1.13 x 1011)(Q/A), then:
1.13x1012=(1.13x1011)(Q/.36)
27.8 coulombs = Q
...This seems wrong
Yep ... except the units are wrong. They should be V/m. This really isn't your fault because in the original equation the units for the 1.13 x 1011 are actually Vm/C.
Close, 2 mm = 0.002 m.
For part (c), you know Q/A = 10 and you want Q. Do you know A?
BTW, these seem like really big numbers. Are you sure that Q/A = 10?
Don't you divide 2mm by 100 twice to get to m?
Yes, A is 0.36m. They give the dimensions of the plates as .6mx.6m
Yup, that's what they give in the question. It says charge density is 10 Coulombs/m2
No, there are 1000 millimeters in one meter so 1 mm = 0.001 m. You might be thinking of converting cm2 to m2. The square means you have to convert twice (and a cube would mean convert three times).
Did you get the answer to part (c)?
I posted it above ^ you didn't say if its correct or not lol.
Oh, I see. Sorry that one's wrong too.
But it's even easier to do this:
Q/A = 10, and A = 0.36 so, 10 = Q/.36 ...
So then the final answer is 3.6Coulombs?
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 18 ·
