What is Energy at Its Core?
  • Thread starter JJBladester
  • Tags
    Energy
In summary, energy is the ability to do work and is a prerequisite for force. It can take different forms, such as gravitational potential energy, electrostatic potential energy, and kinetic energy. Energy is also the source of the gravitational field and is measured in various ways. However, the exact nature of energy is still not fully understood and is a subject of ongoing research and debate, as described by physicist Richard Feynman.
  • #211
Drakkith said:
Isn't this like the whole point some of us has been trying to make? Science has specific definitions and meanings for everything. If you don't agree then you don't agree and there isn't anything we can do about that, which is fine. However if you are going to argue on Physics Forums, then you cannot say that science is wrong and expect to be taken seriously. ...
So you have not seen benefit in my argument that physics should give physic, meaning referring to physical properties, answers and not involve itself in word exchanges? If the book answers are the limitation of discussion, then, there is a point to my keeping my views elsewhere.
  • #212
James A. Putnam said:
Why not just say it has energy? Kinetic energy of an object is the result of applying a force across a distance, and, the carrier of that kinetic energy can apply force in turn? Yes the object has the capacity to apply force, but, the introduction of that word does not clarify the physical circumstances. Both force and distance are included in equations. Capacity is not inculded in equations. In any case, even if my view does not suffice for others, I still see words exchanged for words instead of sticking to that which we know of as empirical evidence. What we know empirically is that changes of velocity occur for unknown reasons. Fortunately, we do not have to actually know those reasons in order to set up conditions that make certain patterns in changes of velocity useful to us.
In other words, the sum total of the work done by the electron is 0, but it has the energy to do work.
That doesn't make any sense according to the accepted definitions of energy. In any case, you know exactly what it means and you are just arguing to argue.
Our definitions and explanations come directly from empirical evidence. In all these posts I still cannot see why you would disagree with that.
What we know is that changes in velocity occur because objects exert force on other objects. We KNOW this. Attempting to argue that we don't know what force or charge or energy is just shows that you don't understand the limits of science. Science knows that it cannot define force except as something that causes a change in other objects. Attempting to explain what Force or Energy "actually is" is meaningless to science, because it cannot be observed in that context. Do you agree with that?
  • #213
The issue here is that YOU think that our current way of explaining things doesn't give physical answers. At least not in a way you agree with. Science defines itself the way it does BECAUSE it is limited i knowledge, not despite of. That is why things get so specific in meaning. Energy is defined one way, while work is defined another way, no matter how alike the two might be, they are NOT the same thing according to science, so they are defined differently. And really, how can we define something without using other words? Force, time, distance, mass, ETC. That is why we have words in the first place. Without using these all our definitions would devolve down to saying "It's just something".
  • #214
Spectracat,
I do understand. Your response was adamant. I don't need further clarification. You think that I do not know what I am talking about. I need to read and learn about physics and in particular thermodynamics. All of this because my position differs from yours.
"I have no idea what you are talking about when you mention "constant force" or "einstein's energy equation". Are you talking about E=Mc[sup2[/sup]? Because I am pretty sure he didn't use any sort of idea about "constant force" to derive that."
Please check it out.
"I can only conclude that you don't understand what a state function is, and why a state function is different from a path-dependent quantity."
I certainly do. However, I don't think that there is anything I can say about that here. For example, thermodynamic entropy is defined as a state function and its similarities to energy are often put forward to show that it is a state function. It appears that contesting what is or is not a state function would be out of line here.
"No there is not ... that is because work always involves a change in energy! On the other hand, changes in energy do not always involve work. In thermodynamics, the energy change for a given process is defined as the sum of heat and work exchanged. in that process. If no work is done, then the energy change is due ONLY to the exchange of heat. If the process is adiabatic (i.e. no heat exchanged), then the energy change is due only to the work expended during the process. "
I am very familiar with that circumstance. Whatever it has to do with disputing what I have said, I missed it. I do not say that the existence of energy always involves work.
  • #215
Dakkith,
"That doesn't make any sense according to the accepted definitions of energy. In any case, you know exactly what it means and you are just arguing to argue."
Ok, I understand clearly where you are coming from. My questions and responses have no merit.
  • #216
Ok. So you are saying that the electron is brought into existence without needing the application of force. I am not a physicist, but, I find that condition to be subject to debate. However, let's assume there is an electron as you stated and we know of no history of force being applied. I have no problem with that condition. The electron is the source, the cause, the exerter of force. Force begins somewhere before it is applied. I allow for charged particles to represent force without explanation. As I have stated in previous messages, we do not know what cause is and that includes me. I do not know what cause is. I only know what cause does. I do not have an explanation for the origin of cause. Personally, I think that charged particles can be accepted as known causes. Any attempt to explain the origin of their force would require explaining electric charge. I could speculate, but that is not appropriate here. I simply allow for force to exist before it is applied. Its existence is not dependent upon its application. An electron can exert force. I do not know why.
So now the question remains, how can we apply your definition of energy to the electron which has never experienced any force in order to get the correct mass energy of .5 MeV?
  • #217
Dakkith,
When you are arguing that we can't use the word "capacity" in a sentence describing energy and work, yes.
  • #218
I didn't get back to your original message concerning this. I will do that. But, in short form: Saying that energy is the sum of force times distance does not require action. There can exist a force that, if allowed to act, will act across a distance. Both that force and that distance exists prior to the event. Action is not required to justify the statement that energy is the sum total of force times distance. In the case of potential energy, that sum total has not yet been calculated because an event has not yet occurred. The force exists. I do not know what distance that force will be permitted to exert itself across. What ever that distance is, both that force and that distance exist prior to its use. The existence of potential energy is the recognition that a force exists and if that force is permitted to act upon an object for a given distance, then kinetic energy will result. The existence of kinetic energy is not required before the existence of force. Kinetic energy is an effect after the cause. We do not know what cause is. Patterns in changes of velocity are all that we have to learn from. The cause, or very speculatively 'causes', are given.
  • #219
This word substitute represents physics to you?
  • #220
What are you talking about?
  • #221
I am talking about your reliance upon the word capacity as if that clarifies the concept of energy. Energy is sufficient. It does not require other words. It is what it is. It already includes force either active or potential. I think I have asked something very much like this before: What is capacity if it is not force?
  • #222
What do you mean energy is sufficient? The word energy has no meaning if you cannot define it, which requires words like capacity and work and such. Is that what you were saying or did I misunderstand you?
  • #223
This is essentially what is meant by "capacity" to do work. As soon as you start talking about some X that may occur in the future given the appropriate circumstances you are talking about the capacity for X. That is why the definition of energy as the capacity to do work is important. You cannot get rid of the word "capacity" without introducing the same concept again, as you have demonstrated.
  • #224
I can use the word force. Force is a real physics property.
  • #225
If you are talking about possible forces that may be exerted in the future given the right circumstances then that is the capacity to exert force.
  • #226
No, you cannot use force as a subsitute for Capacity without completely altering the sentence. And this is about language and grammar now, not about physics.
  • #227
Energy is a physics property. Borrowing words that do not exist in physics equations does not clarify those properties that are included in physics equations. I define energy as the sum total of force times distance. Due to earlier necessary clarification that sum total can exist actively as completed or it can exist potentially so that it can be completed at some future time. Energy, even though we cannot explain force, is sufficient in itself to explain itself. It is the sum total of force times distance whether active or potential. No we do not know what force is. The word capacity does not tell us what force is. It adds nothing to that which physics equations already tell us. Please define the word capacity so that it has relevance to physics equations? What I mean by this is: Capacity can either be included in physics equations or it has no place in explaining physics properties. There is no place for a property called capacity in physics equations. There is a place for both force and distance.
  • #228
Spectracat,
No, I made those comments because your posts don't make any sense, and it's not like I haven't tried to understand them. So you either don't understand these things, or you are unable or unwilling to communicate what the distinction is that you are trying to draw. You have provided precious little in the way of descriptive examples or references to back up what you are saying. You APPEAR to not understand why it is important that change in energy is a state function, while work is not. You APPEAR not to understand that your description of energy as "force times distance" doesn't make any sense in the context of physics, because "force times distance" (or more correctly the integral I indicated above) is the definition of work in physics. Are you saying that integral is NOT what you are talking about when you say "force times distance"? Then what is the mathematical formulation of your statement? Please give the equation. You have made a lot of vague phenomenological musings about "sum total of force times distance", but it is not at all clear what you mean.
Really? After all the work I and others have done to help you understand what we are saying? You can't be bothered to provide a clarification about a casual comment you made that appears to not make sense?
Well, you appear to be saying either that "force times distance" is not path-dependent (which makes no sense as I have already pointed out), or you are saying that energy is not a state function, which is flat out wrong.
Yes, you do .. because you are defining energy in the way work is defined in physics. You have already said that you consider work and energy changes to be completely equivalent in the context of physics, with the only difference being a semantic one.
  • #229
What is energy.
Well let's suppose you take everything away but leave just a minute thing behind.
Gravity , Mass , Potential,light, force, distance,time,the thing you are left with is energy!
  • #230
Energy is a word, just like capacity. We use the word Energy to define something, JUST like we do with Capacity and Force and Mass and everything else.
Explain Energy without using Force, Time, Distance, Mass, Velocity, or any other word. You cannot.
Of course not. Why would it?
How can you explain equations without words?
You are either SERIOUSLY in need of education, or you are being ridiculously stubborn.
  • #231
Due to earlier necessary clarification that sum total can exist actively as completed or it can exist potentially so that it can be completed at some future time. ... Please define the word capacity so that it has relevance to physics equations? .
Sounds like you have defined it reasonably well already.
  • #232
"ou are either SERIOUSLY in need of education, or you are being ridiculously stubborn."
Oh, ok.
  • #233
No I asked for you to define it so that it can be part of a physics equation. I did not define it. I simply passed that word along because it keeps boucing back as if it has a role to play in theoretical physics. What is its mathematical representation?
  • #234
"No, I made those comments because your posts don't make any sense, .." My posts make sense.
  • #235
When you cast it in the form of a physics equation for your definition then I will do the same.
  • #236
Thread closed temporarily for Moderation.
BTW, please be patient with the close -- we are also dealing with some website lock-out issues right now...
  • Other Physics Topics
9K
