What is Magnitude in Physics?
  • Thread starter Thread starter nehach
    Magnitude
Magnitude in physics refers to the size or length of a quantity, always expressed as a positive value or zero. For vectors, such as displacement, the magnitude is calculated using the Pythagorean theorem, which involves the square root of the sum of the squares of its components. Displacement is a vector quantity that represents the change in position from an initial point to a final point, with its magnitude being the straight-line distance between these two points. Unlike distance, which is a scalar quantity that depends on the actual path taken, displacement focuses solely on the initial and final positions. Understanding these concepts clarifies the relationship between magnitude, distance, and displacement in physics.
nehach
Actually, i have just been to class 11th so i m not clear about magnitude so please help me in knowing magnitude and magnitude of displacement...
what is magnitude in physics?
Science news on Phys.org
Basically, magnitude just means how big it is.
If you have a vector (in, say, three dimensions) \vec x = (x_1, x_2, x_3) then the magnitude of that vector is given by (Pythagoras): |\vec x| = \sqrt{x_1^2 + x_2^2 + x_3^2}.
still not very clear how it is related to distance and displacement...then wt is magnitude of displacement.
Welcome to PF!
nehach said:
Actually i have just been to class 11th so i m not clear about magnitude so please help me in knowing magnitude and magnitude of displacement...
Hi nehach ! Welcome to PF! :smile:
"magnitude" is a long word which means something very simple.
As CompuChip says, it just means how big something is.
For example, if something is displaced along the x-axis by 3, then the magnitude of its displacement is also 3.
But if something is displaced along the x-axis by -3, then the magnitude of its displacement is still 3. :smile:
(magnitude is always positive, or zero.)
Displacement is a vector quantity defined as the change in position - from an initial point i to a final point f. Its magnitude is the length of the straight line between i and f and its direction is from i to f. The actual path taken is irrelevant.
Distance is a scaler quantity defined as the path length, i.e., it does depend on the actual path taken. Distance only equals the magnitude of the displacement for straight line paths.
Hope this hepls :smile:
if a person start from i and reach to f
distance between i and f is 5 km
i ----------5KM------------f
now kindly tell me what is magnitude and what is displacement
kindly tell me the formula how to calculate both of them
because i am confisued in this
Hi nehach! :smile:
Displacement: 5 km East.
Magnitude: 5 km.
thanks tiny-tim now its clear to me
hey could u please give me ur gmail id so that instead of wasting our time
we can discuss any problem directly
if u think ok
kindly give me ur gmail id
and kindly tell me the formula of calulating both displacement and magnitude
Displacement is a vector quantity. It has direction and magnitude. The absolute quantity of vector is its magnitude.
You can use the formula posted by CompuChip to calculate it
Sorry if I said something wrong
Simpler still, magnitude is the size or length (always positive or zero) of a vector, independent of the vector direction. "Displacement" in Newtonian physics, is a vector, and has two elements, a signed length (positive, negative, or zero) and a direction.
thanks jeff i got it
