What is polarization in the language of photons and QM?
touqra
I know what polarization is in classical EM. But what is polarization in the language of photons and QM? I am thinking that it's something to do with spin.
It is said that two eigenstates of spin correspond to two kinds of circularly polarized states, but I don't know the details too.
Anyone knows what subject deals with this stuff?
Thank u!
Photon polarization is usually described in terms of helicity, which can be
+1 or -1 for a photon. The helicity +1 state correspond to Left circular polarization and the -1 to Right circular polarization. A plane polarized photon is the same linear combination of circular polarizations as in Classical EM. The reason H=+1 corrsponds to LH circular polarization is that particle physicsts use a z=axis in the direction the photon is moving, while the classical circular polarization is how the E vector rotates as you look toward the oncoming photon.
I still want to know how helicity is related to polarization.
Can you recommend some readings?
Thank you!
Thank you!
Well, they are not directly related in terms of a formula because both concepts come from different "places" in physics. Polarization comes from EM and helicity is a QM concept since you need the concept of SPIN to define helicity. You do not need spin to define polarization.
Polarization can be defined for both materials (local fluctuations in the electronic density that lead to dipoles or quadrupoles) as well as EM waves
marlon
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
